Old 09-06-2015, 03:36 PM   #1
Oil leak in gracey around the oil filter
Changed the oil and develo0ed a leak around the oil filter I believe or it may be coming from the filter relocation thing. The relocation thing moves with a little force as if it was made to do so so I'm not sure I have a 370 85 Bluebird and were on our way from Colorado springs to the coast of Orego . So any advice would help a lot thanks!!!! Also she seems to be running hoter than I think it should allthough the gauge says its good. Anyone have experience with this ???
James ford is offline   Reply With Quote
Old 09-06-2015, 08:37 PM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Pics would go a long way.
I'm hungry!
You Gotta Let Me Fly
Old 09-08-2015, 11:09 AM   #3
Chassis: B3800 Short bus
If the leak only started after replacing the oil filter I would pull it back off and see if you have some gunk between the o-ring and the seat. Wipe everything down with a clean rag, use your finger to apply some clean oil to the o-ring and try again.
If it's coming from the filter relocation unit you might just need to tighten the hose fittings.
Old 09-08-2015, 11:46 AM   #4
If not gunk...check the torque. Many oil filters are designed for relatively light torque and over tightening will cause them to leak.
Old 09-08-2015, 05:23 PM   #5
That was it guys thanks for your help
