Old 06-10-2019, 02:31 PM   #1
Coachwork: Ford
Chassis: E-350
Engine: 7.3 diesel
Question - Can I remove this?
Not a drivetrain question, but probably mechanically related.
Ford E-350
What's behind this bump? I want to put a passenger seat right next to the driver's seat and can use a double Transit seat with integrated seatbelts, but I want to know what's behind the wall and whether I can move it back a bit to give the passenger more leg room.
Thanks!
WanderlustLessons is offline   Reply With Quote
Old 06-10-2019, 02:39 PM   #2
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
Whatís behind door #1?
Simplest way to find out if you could would be to pop Ďer off and look. Iím assuming you canít.
To me it looks like a part of the doghouse. Essentially a housing in the interior that allows clearance of the engine and trans bell housing on van and transit FE style buses and some dog noses. There might be enough clearance to customize yours so that itís flush with the larger portion but you need to ensure thereís adequate heat shielding and airflow around that piece so it can do itís job.
I wouldnít remove it, but Iíd build around it. Just my $.02
-Nick
WARGEAR is offline   Reply With Quote
Old 06-10-2019, 02:51 PM   #3
Traveling
Looks like the transmission tunnel, no it can't be moved.
Old 06-10-2019, 04:31 PM   #4
Ford E-350
Thanks!
The engine is behind that. Its not movable.
Roll Your Own Build Thread
