Old 12-08-2016, 01:20 PM   #1
90 chevy 6.0L / Trans
I have a 90 model with the 6.0 and auto trans. Can someone tell me what type of transmission would have likely came in this? I believe it is a 3 speed. It is shifting hard and is missing the dipstick, would like to get some parts and filter for it, etc.....Thanks for the help!!
James
jamesac91 is offline   Reply With Quote
Old 12-08-2016, 05:24 PM   #2
GM didn't come out with the 6.0L until the 1998 model year in most applications.
In 1990 it would have been a 305 or 350 small block or a 454 big block. The transmission would have been the TH400 or perhaps the TH700R4/4L60.
If it really is a 6.0L it would be the 4L80E or the 6L80 or 6L90. If it is the 8.1L it would be the 4L85E or the 6L80/6L90 or the 8L90.
Old 12-09-2016, 07:12 AM   #3
Rameses's Avatar
Or did you mean to type 6.2?
If that's the case, it's also very likely a TH400.
Rameses is offline   Reply With Quote
Old 12-09-2016, 08:31 AM   #4
Engine: Navistar 7.6L
You forgot about at least one other big block............
It could be a 366 (6.0L) big block Chevy, used in school buses up to the mid 1990's.
DoubleO7 is offline   Reply With Quote
Old 12-09-2016, 09:10 AM   #5
Yes, mine is the 6.0L / so all my paperwork is saying. May have to check the motor itself...not sure where to look though. / where on the trans itself would I look to get a better idea?
Old 12-12-2016, 08:35 AM   #6
check via pan shape/config/bolts
Transmission Identification Chart
Old 12-12-2016, 12:58 PM   #7
You are correct in the medium duty chassis. But in the P-30 and G-3500/4500 chassis the only big block available was the 454 car and light truck engine. The big block Tonawanda truck engine never made it into the light duty chassis.
Old 12-12-2016, 03:28 PM   #8
I could not tell by his post what Chevy type bus.
Assumed:
Old 12-12-2016, 03:48 PM   #9
that is like mine.
Old 01-03-2017, 05:59 PM   #10
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
I have a 1974 chevrolet bluebird c60. The engine in it is a 350ci 5.7L. The transmission is a Alison at545. If your bus has a 6.0L 366ci. The transmission is most likely an Alison transmission.
The Chevrolet medium duty Kodiak truck used the same drive train. Your bus looks to be using gen 1 flip front hood. Hope this helps. Gordon
Tootalltechie is offline   Reply With Quote
