09-11-2016, 09:02 AM
Chevy 366 carb adjustment
Hey all,
I'm a newbie and I just picked up a 1987 Bluebird 62 passenger bus in Oklahoma city. Will I've been making my way back to Virginia and it's been one thing after another.
I had the carb replaced with a rebuilt performance carb as I was able to ascertain that the distributor had been replaced and not all the barrels on the previous carb were opening so she would lose power if you dumped the throttle and you'd have to slow down to 15mph in order to get back on it.
Great so the new carb was awesome for about 300miles, power felt good, solid acceleration then randomly I started experiencing power loss, backfires and I couldn't maintain 40mph. Shut it down, pulled over everything looked fine. Started right back up but still didn't have the power it did before, I could get back to 50mph but it took forever... Worked fine for a while then again, back fires (acting like fuel is being dumped to the exhaust and detonating not necessarily combustion during exhaust stroke), and missing. And now I'm in Kentucky and I can barely make it up a hill.
This all seems like an adjustment issue, since I replaced the plugs, wires, air filter and fuel filter. So any tips on adjusting this thing? Or am I missing something else? It seems odd that the problem is intermittent and is fixed by turning off then back on.
As a side note, the drivers side rear brake locked up... Going to make a different post about that but since I have a limited set of tools I've got a mechanic coming out before I keep driving (it was glowing red and throwing sparks when I noticed it, so I slept in a dirt lot last night). So any general tips on that are appreciated, I'm definitely feeling a bit overwhelmed at the moment.
Thanks
09-11-2016, 09:20 AM
Fuel filter(s) there's likely more than one. There MAY be one in the tank, there MAY be one on the fuel line and MAY be one in the carb inlet.
Don, Mary and Spooky the cat.
09-12-2016, 11:17 AM
Thanks, I've done the fuel filters, going to check the timing today maybe it's a little too retarded.
09-12-2016, 11:36 AM
is it possible you have crossfire through the wires or a couple plugs fouling up with oil and so they refuse to fire? this would cause it to fee llike it has no power and would backfire out the exhaust.. im assuming its not puffing and popping under the hood but out the exhaust?
if its puffing and popping out under the hood you could have distributor springs sticking or if its an HEI style distributor the ignition module could be heating up and then going flakey but id look at the possibility of wires or maybe plugs fouling out ..
09-12-2016, 12:07 PM
Year: 1978
Chassis: Lifeguard
Engine: 366 Chevy
Originally Posted by snorris8236
Hey all,
This happens to me almost monthly. On my 366 I have 2 plugs that refuse to stay connected to the wires for long. Replaced the plugs, replaced the wires; but it keeps happening. Wrote it off as character.
Thanks
Rear brakes can be a PIA if they lock-up. Mine did it and caught fire before I noticed it. I went the expensive route and replaced everything from the brake booster back. Two years later, my passenger side front went up in flames. This time I caught it in time so only needed to replace caliper, rotor, and pads: $230 parts, $210 labor.
Sorry to hear your luck is as bad as mine, but these old busses probably need everything overhauled just to be safe. Right now I'm searching in vain for a steering pump cap seal. The cap is no longer available and every material I try to use wastes away in no time.
Good luck with your repairs.
09-19-2016, 01:08 PM
I will troubleshoot this here shortly but you may be on to something. All the fuel filters are brand new and look great, the fuel pump seems to build pressure and I just adjusted the timing (though maybe a tad advanced now as its hard to start when hot, oops ;). Feels pretty good but still not as good as when I first replaced the air filter, plugs and wires (as I mentioned I did all that and the problem showed up about 200-300mi later I believe).
Not sure about the distributor style, is there a way I can tell? I only know that it is not the stock governed distributor, which is why I was able to easily throw a performance carb on there instead of the governed stock type. She starts right away, runs fine at idle its just the acceleration and power up hills is non-existant now. I don't get how for 200-300mi of that journey I had no problem cruising at 55mph now all of a sudden its a struggle.
09-19-2016, 01:10 PM
Yikes, we're in the process of doing the interior already and we plan to drive it out to Colorado in October... I would hate to be catching on fire and blowing tires during that trip, I think you just made a good case for replacing all the calipers etc. now. Going to take it a professional this week to get it inspected etc and he's been a family friend for a long time so hopefully he can help me get it sorted out to make this trek. I sure as hell don't want to be breaking down ever 200mi like I was on the way back from OKC last week.
09-19-2016, 01:46 PM
it could be that your fuel filters clogged up right away too.. there could be a lot of tank rust which would kill a fuel filter right away..
as for the distributor.. a typical HEI GMC style was the one with the coil in the cap... that was used for many years...
over-advanced timing will definitely cause hot starts and will make it ping like crazy on hard pulls..
on my old classic cars i used the clear inline fuel filter and a little gauge inline past the fuel pump.. when i had issues i could always look at those under the hood and see if the filter looked bad or if I was losing pressure past the filter..
if your carb or intake gasket is leaking you'll also lose power as it will Lean out on you.. a vacuum gauge on the manifold will help you to determine if you have massive vacuum leaks anywhere..
09-19-2016, 03:44 PM
That's all great advice, I'll make sure we get a vac gauge on it and I'll check the filters again, there is a clear inline filter right by the car that still looks good and fuel color looks normal but the cost of replacing those again is so minuscule I'll probably change them again just to be safe since it was sitting in Oklahoma with a 1/2 tank of gas for "six weeks" (yeah right!) when I picked it up.
09-19-2016, 03:53 PM
did you adjust the floats in the new carb when you put it on? trying to think of all the gotchas.. is it hitton on all 8 cylinders? if its idling does the engine shake? or if you go back to the exhaust and put your hand near the outlet is it smooth or a lot of rhythmic pulsing? trying to figure out if we just have a good old fashioned "miss" only hitting on 6 or 7 cylinders..
09-19-2016, 04:02 PM
It idles smooth as can be, I have not adjusted the floats since the installation. I don't think I explained this correctly before so let me try to recap. You'll run fine, there is a bit of a power loss (compared to those first 200-300mi like I said) but it isn't significant when you're running on flat ground (hills can drop me to 25mph depending on the grade and the speed/RPM at which I started at and I don't mean 10% grades I'm talking sometimes a 5% grade will bring me grinding down to second gear (it may also be helpful to note this is a 4speed automatic [old Allison I believe])).
Okay so the minor power loss aside the real symptom of concern is that I can drive for a few hours (or sometimes less) and then out of nowhere it is like the engine starts to feel almost like its cutting off, it quiets down, the power loss is huge and before you know it you've dropped from 55 down to 40 and hitting the accelerator down to the floor does nothing you continue to slow until you hit 40, and then it just feels weak as hell and you can't accelerate back up. It did this before the timing adjustment and at this point you can usually cruise at 40 till it does it again and you slow more. Before the timing adjustment this is when the backfiring (detonating in the exhaust like you mentioned, no true backfires where you're getting that monumental gun shot sound of exhaust valves being open during combustion). Now at this point the bus is just slow, and I'd pull over usually get some fuel, food whatever. Hop back in the bus after as little as 15 minutes and you can get back up to 55 no problem for a few more hours.
Which leads me more in the direction of some spark/distributor related problem unless there is some electronic system I'm not aware of that could be bugging out.
09-19-2016, 04:06 PM
So my rambling aside, thank you again. Now my questions for you would be, how can I thoroughly check I'm hitting all 8, just check the spark at each cylinder and recheck each plug to make sure they didn't get fouled up (I've put ~1000 mi since I replaced them). Also when I get that major power loss it doesn't feel smooth it sometimes kind of bucks (essentially: power loss... lets go... wait no power loss... wait lets go... okay now f*** it I quit)
09-19-2016, 04:36 PM
That feels electrical/ spark to me; on/ off is often a symotom of electrical.
Plugs can foul up if a valve seal is bad which is super common on the 80s gmcs.
Also distributor or cap and rotor? I just had a flash of the coil. That is a part that would heat up and lose connection, and act intermittent if it id going bad.
Plus those coils have quite a few connections in the dis cap that could be coming in and out. My vision suggests the coil.
Btw this is the guy who visited
09-19-2016, 05:11 PM
if it has HEI distributor it sure sounds almost like that module is missing spark..
im assuming when its running real bad that you pull over it still idles smooth?..
your trans is likely the AT545? (makes a whistle / whine when shifting first to second)..
if its firing off backfires into the exhaust pipe.. (not under the hood but under the bus).. then it definitely sounds like ignition.. I suppose you could have a valve sticking open but from your descriptions it doesnt sound like that..
fouled plugs would be fouled even after the bus sat stopped.. esp if they were oil fouled... fuel fouled they may dry up but that would still indicate that spark had failed going to the cylinder...
I had a rare case on one of my hotrods where the hotter my engine got the lower my fuel pressure went unti it couldnt fill the carb up... id sit, cool down and then go again.. my issue was fuel lines were too close to the exhaust and were getting hot.. causing the fue to vaporize in the lines before the carb.. the gauge is what caught that one... id start out with a nice 6-9 PSI and after driving awhile when i stopped the gauge would be reading close to 0 and id have power loss.. I popped out the carb under the hood a bit sometimes when that conditon existed as i was leaning out.. but did not pop in the exhaust under the car...
that car also ran better and longer on a cool morning and longer the first time you started out than after it sat.. .so for instance I might drive on a cool morning for 100+ miles when I first started.. but park and then in the afternoon Id only drive 40 or 50 before id sputter... and then look to see my clear fuel filter mostly empty and the gauge on zero... never had anything like that before or after that one car..
I fixed that by replacing my metal lines with AN rubberized steel and moving them away from the engine as much as possible.. and then I ran my fan more aggressively to keep the engine compartment temps down...
09-21-2016, 12:56 PM
Coachwork: Crown / Pusher
Buddy of mine used to have a 240Z that would lose power & die but would restart after a couple minutes, what he found was there was a tiny piece of rust flake in the tank that would get pulled oner the fuel pick up, dropped the tank had it boiled out no more problems.
09-21-2016, 01:47 PM
Hey man! Good to bump into you on here, let me know when you want some company we definitely want to see your bus.
I think replacing the distributor may not hurt and isn't terribly bank breaking either.
09-21-2016, 02:06 PM
Yeah it runs smooth when I pull over and just let it idle.
The previous owner put a really cheap universal electric fuel pump on it, well really two (one feeds the generator if you have it running), the generator one I noticed was leaking so I removed it and stuck just a piece of fuel line there to prevent leaks (that was all after this problem was noted though). So I'm debating on just replacing both fuel pumps. I did a little googling this morning and it seems the fuel pressure should be around 7-9psi at idle and no less than 4 at full throttle. The pump on there is this:
https://www.amazon.com/Mr-Gasket-12S...rb_top?ie=UTF8
It gives a range of 4-7psi and is of unknown age so maybe it has been sucking up crap and is struggling to perform over long periods of time?
09-21-2016, 02:08 PM
Man I hate the idea of dropping the tank but after rethinking all these options this is a real possibility since both fuel pumps are technically gravity feed (sitting on the side of the tank) it could easily be something silly like this. Well I'll start with this and work my way through fuel pump and spark issues next and see if I can get this figured out. Will update when I have some news.
09-21-2016, 03:29 PM
Chassis: IH
Hang on ... I wonder ... ... ...
Your fuel tank isn't building up a vacuum, is it? Next time it gets weak, crack open the fuel cap. A gush of air going into the tank is a fair indication this could be the problem. After venting the tank, see if power is back to normal.
09-21-2016, 05:02 PM
great idea I hadnt thought of!!.. and one i had bite me once in a car where the fuel tank vent was plugged
