Why would you recommend putting them in front of the radiator?
They are less efficient there.
I've seen some 40 amp relays die under the use of those fans. The best thing to do is get the relays that came with the fans. Otherwise, 12voltguy.com has some kickass higher draw relays/solenoids.
