Old 09-25-2018, 12:52 PM   #21
Engine: 6.0L 366 Chevy Big Block
Rated Cap: 47
Did you end up doing this ? I am interested if you did . I recently purchased a bus with the same engine and would love to put an electric fan on it .
arod79sae is offline   Reply With Quote
Old 09-25-2018, 04:42 PM   #22
Coachwork: None yet
Originally Posted by timbuk View Post
a thought if it takes 10 hp to run a fan how much is saved with a electric water pump?A good place to make power in a skoolie...timbuk
BMW does this in many of their current engines. It's an absolute nightmare. But that's more due to their ideas about engineering than the fundamental idea.
cycle61 is offline   Reply With Quote
Old 10-01-2018, 12:39 PM   #23
Rated Cap: 47
From my understanding most modern buses actually use electric cooling fans . Some use some type of hydraulic fan too . Just allows for more control of fan speed which contributes to noise and then you don't have the issue of cooling past what you need .
Pusher problems? Engine layout, parts, cooling...? Elliot Naess Mechanical and Drivetrains 10 08-25-2015 03:00 PM
Electric bus. stonestatue School Bus News 0 06-17-2013 01:24 AM
Electric Mayhem GonzoStreet Electrical, Charging and Solar 10 06-15-2010 03:04 PM
electric stove? Mulelover Alternative Fuels | Electric, Propane, Wood & Biofuels 8 01-24-2010 08:45 AM
Idea- rear heater under bus as additional cooling? RyanS Conversion General Discussions 2 07-11-2009 07:22 PM
