Old 05-22-2013, 06:48 AM   #1
Re: GMC 351 V6 Throttle spring
I am confused
Why is the spring keeping it from closing?
Are you sure it's not the idle screw that is keeping the throttle plate open?
Normally the spring just pulls the plate closed to overcome the cable resistance etc
take off the cable and spring and use your hand to close the throttle, look down into carb,is plate closed all the way?
If not look for the idle screw, it will be touching the linkage at some point,this may be the issue with plate not closing
--to idle; air must be allowed to "leak" around the plate,idle airscrews and holes in throttle plates and other passages (dependant on carb...this is very general example) do this as well as idle screws slightly holding plate open
The spring mounted should be at angle that will not allow the spring to be extended and "wrap" or touch the throttle shaft at WOT
A pic of your setup would help
5.9 Governor Spring kc_4_jc Conversion General Discussions 2 02-17-2013 12:45 AM
throttle issue smitty500 GM | Chevrolet Drivetrain 3 04-02-2012 07:08 PM
Air throttle - 8.3 Cummins opus Cummins Drivetrain 2 12-12-2010 06:57 PM
Throttle conversion cschlessman Cummins Drivetrain 1 08-20-2010 03:15 PM
What I did this spring, by Firearm... Firearm Everything Else | General Skoolie Discussions 10 07-22-2005 04:51 PM
