Old 08-05-2018, 09:40 PM   #11
CCurran88's Avatar
Chassis: 2003 International CE; 2 A/C Units; PS; Air Brakes
Engine: T444E 7.3L Diesel Engine
Rated Cap: 72 Passengers
Wouldn't happen to have a name or contact for junkyard?
Quality Parts Supply
15844 I-35, Bruceville Texas 254-867-4629
CCurran88 is offline   Reply With Quote
Old 08-05-2018, 09:42 PM   #12
I'll contact them tomorrow and see if they have a door.
o1marc is online now   Reply With Quote
Old 08-05-2018, 10:11 PM   #13
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
finchwagon
Do me a favor, crawl under your bus and get the information on the type of axle housing you have.. I am willing to bet I can find more differentials that will fit but I need the housing type....
example my 2005 ford uses a dana/spicer S110 the international terrastar also uses a dana S110.
the lowest ratio found in the fords is 4.30 found one oddball said 4.1 the terra star i found was a 3.73
Iwill look around for you, if you can get the axle type information. there should be a metal tag some where on the axle housing.
william
Old 03-13-2019, 05:22 PM   #14
Lorena yard
Yes name place ls called Quality Truck parts in Lorena Texas
Chuckfwisd is offline   Reply With Quote
