Old 07-09-2010, 10:12 AM   #1
Year: 1987
Coachwork: blue bird
Engine: gmc 366
looking for some tune up info for 366
hello fellow skoolies, I just picked up an 87 bluebird with a 366 gm engine, just wondering if any one knows what the spark plug gaps are supposed to be and what the timing is supposed to be set to, or if someone can tell me where to find this info, it would be greatly appreciated.
Just doing a tune up on it, as it didn't run too smooth on the drive home.
newskool is offline   Reply With Quote
Old 07-09-2010, 10:38 AM   #2
frank-id's Avatar
366 gas tune up
I would recommend strongly to perform a compression test. First make a dry test of all the holes then again with a few squirts of motor oil into each cylinder.
Carefully determine engine condition by checking each spark plug. Each spark plug will tell that cylinder internal condition and this information will indicate what temperature range the new spark plugs should be. Use the best quality parts rather than making a parts choice by price. GM engines often require new plug wires because of the wires routing. Water/alcohol or propane is a good cheap power maker for a gas engine. Frank Hot in Idaho
DTA 360 info the_experience03 International | Navistar Drivetrain 22 06-29-2019 09:15 PM
Help & Info Please !! TheHobbits Conversion General Discussions 15 02-21-2013 08:05 PM
5.9b or 6bt tune and performance bansil Cummins Drivetrain 8 10-11-2012 12:47 PM
bus info newtoskool Conversion General Discussions 1 07-29-2010 02:53 PM
Leaving and Need tune-upish advice kirkndopp Conversion General Discussions 3 12-11-2009 09:27 PM
