Old 07-06-2016, 10:25 PM   #1
no throttle response Chevy 366 Holley 4 barrel
I have a 1987 Chevy bus with a 366 cid and 4 barrel holley carb. Currently the bus will idle, but there is no throttle response. The throttle is stiff, so I believe the redundant safety spring is tripped. Does anyone have a picture and instructions for resetting? I can manually open the secondary and engine revs up. Tomorrow, I will check the secondary diaphragm. I was told that it could be a worn out base plate too. Any thoughts? Am I on the right track? What else should I check?
Meachamr is offline   Reply With Quote
Old 07-26-2017, 09:40 PM   #2
Question No throttle,
Did you ever figure out what this problem was? are you still on this board. Does anyone on this board have any answers to this question?
songboat is offline   Reply With Quote
Old 07-27-2017, 04:12 AM   #3
other than checking the linkage, is simple task to get another holly carb, or even quadrajet with its manifold and change. i much prefer the quadrajet and sell the hollys at the swap meet
Old 07-27-2017, 08:49 AM   #4
It all depends upon which Holley carb is on the bus.
If the carb is like most that I have seen on buses, the throttle plates are not physically attached to the throttle linkage. The throttle plates are vacuum operated so that they will act as a governor to prevent engine overspeed.
Over time those vacuum actuators can wear out and cease to function.
As far as a stiff throttle linkage is concerned, there could be a lot of reasons for that. The top reason is there is a kink in the cable between the pedal and the carb.
A picture of the carb would be helpful.
Old 07-27-2017, 03:38 PM   #5
thank you so much, I drove it and parked it where it is had no problems, been sitting about 6 months, went out and it cranked right up but accelerator is no longer connected to something it will not rev up so I figure it's something simple, it is a 1991 GMC 6000 Fuel injected,366 Tonawanda converted to gas. I will be asking more questions I am sure. Will get a pic of the carb and more info asap.
Old 07-27-2017, 04:50 PM   #6
Does it have fuel injection or a carb?
There are a lot of differences between the two.
Regardless of the system, if you move the throttle by hand under the hood do you get full throttle? If you do then you will know the issue is in the linkage. If you don't you will know the issue is inside the carb/FI body.
Old 07-27-2017, 07:27 PM   #7
fuel injected
Old 07-27-2017, 07:29 PM   #8
as I recall full throttle from under the hood.
Old 07-28-2017, 12:05 AM   #9
Okay.
Let's start over.
You have a bus with the 366 big block and it has fuel injection and not a carb.
If you take the air cleaner off and you look at the FI body it should look like a carb with a bunch of wires going to the injectors. There should be a set of throttle plates in the bottom that open and close.
When you push on the throttle inside the bus, what happens to the throttle plates?
If nothing moves then the problem is somewhere between the pedal and the throttle body.
If the cable moves and the throttle plates don't move there is something wrong with the linkage between the cable and the throttle body.
If you can get the throttle plates to move by manually moving the plates while under the hood the problem is going to be somewhere between the pedal and the throttle body.
If you can't get the throttle plates to move then you are going to have to remove the throttle body to discover what it is that is preventing your throttle plates to move.
Pictures of what you have would be helpful.
Good luck!
Old 07-28-2017, 03:33 AM   #10
speaking of fuel injection... one can remove and install carb... may need to build intake manifold... my machinest neighbor did that after someone told him it couldnt be done...
