Old 08-12-2012, 08:21 PM   #1
Atridox's Avatar
Engine: Gasoline
rear end gear ratio change
1986 Blue Bird on a Chevy c-60 with a 366 gas engine. I want to change the gear ratio to improve mileage. I am having difficulty finding a source of parts. Any suggestions would be helpful.
Thanks.
Atridox is offline   Reply With Quote
Old 08-13-2012, 04:53 AM   #2
Coachwork: toyota
Chassis: z 201
Engine: toyota 4y
Rated Cap: 1
Re: rear end gear ratio change
May be changing the ratio of the gears would solve the issue but do take an advice from an expert before changing the ratio..According to me there is no harm and would surely boost n the performance but prevention is better from cure so do follow the expert advice...
lanceferro is offline   Reply With Quote
Old 08-13-2012, 09:24 AM   #3
One can easily get ring gear/pinion gear kits as well as the bearing kits at the truck parts house. Yours is a common axle. It would probably be easier just to buy a good used highway geared rear axle out of a normal box truck with the same brakes, pull the cover, and check the teeth and install the whole rear axle, if you don't want to change out the ring and pinion yourself. Your ring gear probably takes rivets to put on, and that requires a press. Bolts will work as well.
For the cost of the parts, i would probably just change out the rear axle for a newer good one. fwiw
« gone | TOP SPEED »
axle ratio change kotflb Everything Else | General Skoolie Discussions 16 11-01-2017 08:28 PM
Rear axle gear ratio. To change or not to change. slade Conversion General Discussions 15 04-24-2017 02:33 PM
Eaton 19050S gear ratio?? Henukaw GM | Chevrolet Drivetrain 8 02-23-2015 01:50 PM
better gear ratio cheap lapeer20m Conversion General Discussions 21 05-20-2006 09:35 PM
Changing the Gear Ratio Mat7103 Conversion General Discussions 6 03-05-2004 07:10 AM
