06-15-2016, 10:52 PM
Chassis: Chevy P-30
Engine: Chevy 454 Big Block
Sometimes when I turn the key...
When I first got my bus, sometimes when I would try to start her up I would get no response whatsoever. Electronics would come on, headlights, horn would work.
Literally, turn key...
No sound, no movement, no vibrations.
After waiting, or kicking something, or making sure the emergency exit was closed and locked eight times, or opening the side door, or saying 4.3 hail marys, then it would roar into life like it was fresh off of the line. It hasn't done this in awhile, because it isn't starting at all right now, but I was wondering if anyone had any insight as to what would cause such a phenomenon.
06-15-2016, 11:44 PM
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Bad starter, solenoid, ignition switch, clutch safety switch on manual transmission. Emergency door or window ajar or a bad switch. Dirty contacts on battery, cables, ignition wires. Try jumping the starter solenoid (manual transmission in neutral). If that won't work let us know.
Hopeless Busaholic!
06-15-2016, 11:48 PM
Chassis: Chevy P-30
She's an automatic trans. I believe it might have been related to the emergency door, because it either stopped all together or less frequently after I dismantled the wiring from the escape hatch. After I get her started from her most recent mishap, I will update you. Right now she isn't starting at all and hopefully, it is just that I need a new battery.
I did go through your checklist when it first started happening, so I must be on the right path and learning more than I thought! WOoHoOO
06-16-2016, 12:43 AM
Chassis: IH
One fellow I worked for had an ancient International gas powered dump truck. It had a tendency to only start when it wanted to. Turn on the key and the lights/gauges would do their thing, but either no starter, or the starter would spin, but not engage the flywheel. We knew the starter was faulty, just never bothered to replace it.
06-18-2016, 02:35 PM
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
OK, since it is an automatic it could also be the safety switch that will only let it start in park or neutral. When it won't start try moving the shifter a little or put it in neutral and see what happens.
Hopeless Busaholic!
06-18-2016, 03:58 PM
Year: 1987
Engine: 6.9L Diesel
I've spent atleast 4 hours total spread over a few days troubleshooting exactly this. The shame and embarrassment felt when I resolve the issue is strong.
06-18-2016, 05:55 PM
My truck does this sometimes, and I cycle it from neutral to in gear back to neutral then key to ff and back on and it starts right up. For whatever reason it seems that it doesn't think the gear selector is secured or something and then have to return to off before re-attempting a start-up. Buses have the added loophole of all the door and window sensors until you get them all disabled or bypassed.
06-18-2016, 08:17 PM
Chassis: Chevy P-30
I got pulled over for not having plates when I purchased my bus. I was flying an "in transit' sign with the title and insurance papers in the rear window, so it was all good... apparently good enough that the bus decided it was the perfect time to pull this non-starting stunt of hers! Haha, I already have some pretty good war stories from the six months that I have actually been able to drive her!
06-18-2016, 09:13 PM
Man, we gotta start a thread about this subject- the crazy stories of early bus ownership. The craziness of owning a bus never truly goes away. I sorta love it, even though I've had plenty of stress over buses in my life. I blame buses for my beard being silver instead of reddish brown @ 36 years of age.
06-18-2016, 09:23 PM
Chassis: Chevy P-30
I believe it! I have lived a very dynamic, unconventional life by most people's standards, but since I got my big yellow chariot... let's just say I have a permanent welt from pinching myself on my arm now. If you think you have been through it all and life holds no more surprises, then you my friend, need to acquire a school bus! Even if I never make it to Burning Man or anything, my schoolie has more than paid for itself in terms of "That just happened!" moments!
06-18-2016, 09:39 PM
Totally understood.
06-18-2016, 11:02 PM
I third the motion; i too have lived a pretty unconventional life and now am moving into a skoolie. Funny how right it feels. Before the bus i got a calling to start looking for a home. I checked a few houses, all seemed cool enough but sorts made my spirit sad. Figured it was just life, then after some Universe guidance i found something that makes my spirit happy.
And yeah... door interlock. lol
06-19-2016, 12:33 PM
Engine: Detroit 8.2
Mine started the shifter problem the first time I took it for inspection?
It was starting to act funny when I started up to go and I wiggled a little and off we went but the mechanic wanted to start it for whatever reason.
For the Jolly Roger I just have to find the sweet spot in the neutral position.
Key twisted to crank and wiggle the shifter to find the neutral sweet spot for me.
