Old 07-17-2018, 11:38 PM   #461
oricha1984's Avatar
Engine: gasser probably
brake booster replaced
so im looking at a shorty that needs a brake booster replaced?
is this over my skill level?
would the bus be drive-able without it being changed ?
oricha1984 is offline   Reply With Quote
Old 07-17-2018, 11:52 PM   #462
You just won't have any power brakes, you'll need a strong leg to get it stopped. I just changed the booster in my Dakota today,bigger PITA than it should have been. I wouldn't want to be in traffic with a bad booster in a bus. I would think it would be easier on a bus. Usually 2 bolts holding the master cylinder to the booster and 4 nuts holding the booster to the firewall or spacer, and a clip on the brake pedal to remove. Bunch of brake switches on a bracket in the way which of course could only be accessed from the wheel well after removing the wheel and inner fender well on mine.
If you can get the master off without breaking any lines loose, it should easily be in your skill level.
Old 07-18-2018, 07:53 AM   #463
You tube is your friend.
Old 05-03-2021, 08:53 PM   #464
oricha1984's Avatar
Teach me more !!!!
I am back !!!
Teach me please.
talk to me about the Cummins 6.7L 6 cyl turbo diesel, with an automatic tranny. on a 2011 DODGE RAM 4500 ambulance body.
Thanks,
Raul
