Timing Blue Bird All American with 427 engine?
Hi folks,
Any advice on how to time a 427 BBC engine? I can't seem to see the timing marks from the top of the engine where the indicator should be located, there seems to be a bent triangle toward the lower drivers side on the crank pulley. There seems to be two marks on the pulley, the line which should be tdc and a dot or circle about 30-40 degrees clockwise to the line. But when the line is at the triangle which I can see from underneath the engine, that doesn't seem like tdc for cylinder 1?
Thanks for any suggestions.
