Originally Posted by Lamacose
On a serious note, make sure the injectors are in good shape.You don’t want to blow a tip off.That will cause serious damage.
Yep, this happened to me! Destroyed the turbo. Had to pull the head and pan to check everything else... not easy on a 6-71, the head had to weigh 300lbs! All because a $40 injector failed!
