Old 02-27-2018, 04:29 AM   #21
Chassis: International S3800
Firstly is your charge system working right? Do you have a solid 13 volts now? I’d be checking that before anything else
Christopher
Old 03-01-2018, 07:04 PM   #22
Coachwork: Collins Super Bantam
Engine: 6.5L Diesel
Rated Cap: 20 passenger
Firstly is your charge system working right? Do you have a solid 13 volts now? Id be checking that before anything else
Christopher
That's a very good question. I left the front battery on a trickle charger for a while but then removed it when I suddenly had to leave, but I haven't checked the second battery under the frame. Do both of them need to have 13 volts?
I tried to look for the OBD2 connector but could not locate it anywhere. In my previous cars/trucks they were normally located under the steering wheel.
jnymdnyt is offline   Reply With Quote
Old 03-01-2018, 07:07 PM   #23
BennysTire's Avatar
Chassis: TC-1000
Engine: 5.9 Cummins 24v
Rated Cap: 39 Students
Further to the left, tucked under the end of the dash plastic. Near the hood release almost...
Sent from my E6883 using Tapatalk
BennysTire is offline   Reply With Quote
Old 03-01-2018, 07:09 PM   #24
the voltage of 13 volts or over would be checmed when the engine is running and no battery charger connected... the alternator should keep the system at 13 or over when the engine is on..
Old 03-02-2018, 09:38 AM   #25
Engine: 6.5L Diesel
Thank you. I was loosing my mind looking for it.
Old 03-02-2018, 09:39 AM   #26
BennysTire's Avatar
Chassis: TC-1000
Old 07-30-2018, 04:14 PM   #27
Engine: 6.5L Diesel
Apologize for being MIA for a long time. I long trip to Alaska and Canada kept me from working on the bus and now I'm back at it again. At least I was able to use it as storage and save me a couple of $$$ from renting a storage space while I was gone.
I checked the battery and the one under the hood is bad and the one underneath measures 13 volts. I am in the process of getting the same battery as before - Intersate MT-78. It's weird how it still starts even after not starting it for a couple of months.
Oh, and the OBDII I have is not the same so I have to figure this out to get the codes.
Old 08-15-2018, 06:02 PM   #28
How'd you come out on tracking the tranny problem? There was a you tube video, a while back detailing the 3 most often found problems with your trans. Also had some other idea on your se up. As I recall they were, for the most part, not too bad on the checkbook, to fix.
Anyone know which Allison would work in this situation?
1olfart is offline   Reply With Quote
