Old 12-28-2011, 02:09 PM   #1
Year: 1985
Engine: Detroit Motors 8.2
power steering geear box leak
Haven't started moved the bus for sometime. moved it the other day and I got a leak at the gasket where the steering gear box/pinon is. It leaks right behind the push rod that connects to the steering arms on the axle. Can I just buy a gasket or do I need to replace the whole steering box ?
butcher_boy is offline   Reply With Quote
Old 12-28-2011, 07:37 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: power steering geear box leak
Could be dry from sitting, shrunk etc. I would run it for a while and see if it stops. That is unless it pours out. Common sense here....
Old 12-29-2011, 12:22 PM   #3
i think you are talking about the steering sector shaft from what i can read, and they are cheap.. but takes a while to r&r. you can clean and adjust you steering box while u have it out... not to mention checking it and tie rod ends, etc.
Power steering Reservoir? ihowell2077 Mechanical and Drivetrains 1 10-11-2013 12:08 PM
Power steering failure auto-sales International | Navistar Drivetrain 0 06-29-2013 06:58 AM
hyrdro boost and power steering leak Chasgoat Conversion General Discussions 1 05-30-2013 05:15 AM
Need help with Power Steering kirkndopp Conversion General Discussions 2 07-07-2010 11:32 PM
Power steering noise captainkf Conversion General Discussions 3 09-22-2007 01:50 AM
