Old 09-29-2018, 09:02 PM   #41
Coachwork: None yet
Don't have time to respond in depth, but thank you all.
cycle61 is offline   Reply With Quote
Old 09-29-2018, 10:50 PM   #42
Hotpuppy's Avatar
Year: 666
Sure thing.... just post if you have questions or need anything. Coaches are a fun adventure and the risk can be managed if you are careful and do your research.
Bus #3- 1985 Auwerter (Neoplan) Cityliner N116/2 Motorhome
See "My garage" in profile for past vehicles and pictures.
My bus blog: https://www.autobus.us
Hotpuppy is offline   Reply With Quote
Old 09-30-2018, 09:07 AM   #43
I have two DD Engines- two things - When it starts (it will). Do NOT GOOSE it. Let it idle for a long time. Oil will settle into the blower side of the intake and it will smoke like crazy- let it do its thing. Idle until all oil is forced to all the places it should go.
2 nd thing. Have a means to choke off its air supply should it start running on. Heavy jacket is what I used. These engines are work horses, fresh oil and clean filters!
Dirtdoctor is offline   Reply With Quote
Old 10-04-2018, 02:53 AM   #44
PB&G's Avatar
Chassis: Supercoach 40'
Engine: Detroit 6-71T
Rated Cap: A lot
Wink
From my 1988 manual.
Only 40 weight is recommended according to this one.
50 in high temperatures over 100F ambient
15w-40 or 30w only in very cold applications from 0 to -25F and never in marine applications.
Watch us on Youtube @ Life of Curiosity
Life in Hawaii, converting a Crown bus into an RV, and other travel adventures!
PB&G is offline   Reply With Quote
Old 10-04-2018, 06:51 AM   #45
Ronnie's Avatar
Engine: 345 international V-8
Thanks, I like facts from manuals. It is interesting they changed from straight 40 to 15w40(as my manual shows) then back again.
Marine applications usually run the engine near full power for long times, and often do not see cold conditions at least not in the boat, so cold weather flow at start up is not normally a concern.
My application is railroad and mine see a lot of idling time, of course set at high idle. I do also have many differant brands of engines so keeping separate oil for each engine would be a nightmare. Found one of the guys putting journal oil in an engine. Yuck this is straight 20w with a tachiness additive.
Old 10-04-2018, 07:18 AM   #46
in a bus theres a good chance depending on how its geared that it will be running at close to max RPM for extended periods of time..
one of the things we had to deal with in racing is oil foaming.. some of the newer detergent oils have a tendency to foam when they turn into a fine mist under high load higher RPM conditions.. granted we were spinning engines north of 6000 RPM.. but still the potential exists and is something to think about when looking for oils that are going to run extended periods of time at higher RPM / high load.
Old 10-13-2019, 10:09 AM   #47
Engine: 6-71TA
Rated Cap: 90
I have not changed the oil on my Crown yet and started looking around for SAE 40 CF-II oil. Tractor Supply has Shell ROTELLA T1 SAE 40 (CF/CF-2) Heavy-Duty Diesel Engine Oil for 14.99 a gallon. Anyone use Rotella for this?
GWRider is offline   Reply With Quote
Old 10-13-2019, 10:21 AM   #48
Sadly I don't own a DD two stroke anymore.
These folks are very 2 stroke savvy :
Detroit Diesel 2 Cycle 2 Stroke Engine operating Oil Tips
Old 10-13-2019, 10:24 AM   #49
Rated Cap: 37,400 lbs GVWR
Rotella T1 is good. I bought nine gallons of it when NAPA had it on sale a few months ago. Delo 100 is favored because it has the lowest sulfated ash content, but any CF-2 oil is OK, especially because we're not driving the high annual mileages that commercial operators rack up.
Old 10-13-2019, 10:29 AM   #50
Engine: 6-71TA
Rated Cap: 90
Thanks. TS has it on sale and at approx. $3.75 a quart it is hard to pass up.
Old 10-14-2019, 09:35 AM   #51
Both are quality oils flee from traveler oils. But with the DRIPTRIOT you might consider getting a lot of it. Cheers
Old 10-14-2019, 09:54 AM   #52
I must be getting old.... My first thought was "$3.75 - that's outrageous!". I bought Delo 100 for less than $50 a case (6 gallons) all the time for my DD two strokes.
Then it dawned on me that I have not driven one in 18 years and sold my last one 15 years ago.
Old 10-14-2019, 10:37 AM   #53
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
that happens as you get older - what happened 'a couple of months ago' turns out to be a year ago - time flies faster and faster the older you get
