Old 03-05-2011, 07:32 AM   #1
Coachwork: carpenter
Engine: international DTA360
Re: 1986 International School Bus Need More Speed
I would choose, first, a different axle ratio- 5.57 is very slow. Call a used truck parts place with your axle info, they can probably tell you what they can get in either a third member ( pumpkin, center section, 'chunk' whatgever you want to call it..) I paid $450 for one with a 4.10 ratio. Wish I had picked a 3.91, but will achieve the same thing with larger tires. Not mechanically difficult to change, but it is heavy and awkward. U-joint type and axle spline type must match, also- they vary within a given axle type, and changing either requires more knowledge than installing the differential does.
Secondly, you could install an overdrive transmission. Most automatics and manuals have a 1:1 top gear; the driveshaft spins at engine speed in top gear. Some have an overdrive, and spin the driveshaft faster than the engine. in older used stuff that you're likely to be looking at, I think you'll be limited to a few manuals if you want this.
lastly, bigger tires- in your pictures, it looks like you may have 10r22.5 tires, which might be about 39" dia. 12r22.5 tires are made, I think they're about 43" od. The top speed gain (at a given engine speed) is exactly proportional to the diameter change. (or radius, or circumference change, whatever you care to use)
depending on your mechanical ability, none are really cheap or easy, but well worth it, if you're going to drive very far. My mileage improvement paid for my trans and axle swap in two 8500 mile trips, plus it is much more pleasant to drive, and faster. top speed went from 58 to about 85, but I go 65 for mileage.
Something I calculated, but wasn't sure of until I saw it, is that the bus pulls hills better with the faster gearing. This will vary depending on the torque curve of your engine and what changes you actually make, but your engine makes very little torque or power near it's max speed. My engine makes max torque at about 1700 or 1800 rpm, more than double what is available at 2900. While climbing a hill, the allison auto would downshift at 2300, then be unable to hold 2900 in 3rd, and I'd end up at 2300 or so in 3rd gear. Now, on a similiar hill, speed may stabilize at 1900 engine rpm in top gear ( I now have a 7 spd manual), giving me more speed and better mileage.
People will disagree, insisting that lower gearing automatically gives better hill climbing, but do the math- the 'thrust' at the axle at any given road speed can increase with faster gearing, especially when you're starting point is running an engine at close to double the speed of it's torque peak.
Turning up your governor will make the above situation worse. You'd have to turn it up a LOT, also. If your top speed is now 55 at 3000 rpm, 4090 rpm would get you 75 mph. You might get away with a little, but very much will be very bad, and I bet in any case, your performance in the slightest hill or headwind won't be very good, and either will mileage.
A slower axle ratio (higher numerically) will, in every case, be better for accelerating from a stop, uphill, etc. Your 6.9 might be only 125 to 150 hp, and not that much torque, so might require a slow ratio to perform acceptably in these situations. and might simply not be able to make a bus go 75 mph without a tailwind.
likesmachines is offline   Reply With Quote
Old 07-26-2011, 12:31 PM   #2
Engine: DT466C
Rated Cap: 60
Just to make you feel better, I have a similar shorty with 6.14 gears.
I have a similar axle in my other one with 4.77, but can't just swap.
Joke's on me, the only axle ratio that the Spicer rear and the Rockwell front
axle share is...............yup, 6.14.
So now I have to swap the rear axle for a Rockwell, and get a new pig for the front.
Anyone seen a '69 F600 around with a 4.63 axle. They had Rockwell F106 rears.
Should be able to find one locally.
Definitely time for a ratio change.
martian is offline   Reply With Quote
Old 09-02-2011, 04:40 AM   #3
ns9987's Avatar
Year: 1987
Coachwork: Blue Bird Conventional
Chassis: International S-1753
Engine: 6.9L IDI
Hey! I have a 5.38 ratio with a 6.9L IDI motor. I noticed you have 20'' split rims on your bus! First, Think affordably here, get you some bigger tires man! Upgrade to the tubeless 22.5'' rims like I have. The tires are more cheaper too! It rides sooo much better than the old split 20's. BUT! If you don't want to go that route just at least get you some bigger tires for your 20's you have. Go with the 10.00R20's for you. They're about an inch or two bigger than what you have. Realistically, we just don't have the power in our 6.9/7.3 IDI motors to turn higher ratios with the setup we have. My bus weighs 15,500 emtpy. And It SUCKS climbling hills! BUT! I love her damnit!! So you'll have to deal with the lack of power going up hill, no matter what. But, flat land, and down grades you can Fly!
In short just get bigger tires! Will help more than you think, and it's the most logical thing to do here. I know you don't want to spend thousands getting a different, higher geared rearend in it and it REALLY suck climbling and suck the fuel right up then.
So just leave the axle be, and get the bigger 10.00R20 tires.
Trust me, I know how you feel. =D
"IF it ain't broke... Don't screw with it and end up breaking it!"
ns9987 is offline   Reply With Quote
Old 10-07-2011, 03:01 AM   #4
ns9987's Avatar
Year: 1987
Engine: 6.9L IDI
Ok man! I have wanted to try out that 4.78 ratio! And excellent job for switching to the 22.5's! You'll be so happy now that you did!
The 4.78 I've heard with having a DT-360 to send it flying, does really well. With that said our 6.9's may have somewhat of a harder time getting it going on take off, BUT when your crusing in 4th gear thats where it'll shine. Now of course it may shift earlier going up hills so 3rd gear will be your pulling gear, and 4th will be more a highway crusing gear.
Let me know how that 4.78 does in your bus, because I may upgrade to that same ratio one day!
Old 07-27-2012, 04:21 PM   #5
ns9987's Avatar
Year: 1987
Engine: 6.9L IDI
Hey man!! Just wanting to know how the swap is going? I can't wait to hear about it!!
Old 07-29-2012, 02:35 PM   #6
Rated Cap: 47
Cool, nice bus.
Motobus is offline   Reply With Quote
Old 12-10-2012, 06:08 PM   #7
ns9987's Avatar
Year: 1987
Engine: 6.9L IDI
Sorry it took me so long to reply!! So, how did the swap go?? How does the 6.9L like it? Does it climb hills ok?
1986 International for sale jlhollowx13 Classifieds | Buy, Sell, Swap 3 07-26-2013 03:45 PM
Our new 1986 International House!!!! jlhollowx13 Skoolie Conversion Projects 17 01-28-2012 03:39 PM
FOR SALE!!1986 InterNational Diesel Gatorskinz Classifieds | Buy, Sell, Swap 6 01-24-2008 04:03 PM
1986 GMC School Bus britishroamer Everything Else | General Skoolie Discussions 4 12-03-2007 08:32 PM
1986 bluebird DT466/5 Speed man/2 speed rear code4 Classifieds | Buy, Sell, Swap 2 08-14-2006 11:29 PM
