Old 05-01-2014, 04:58 PM   #1
Engine: International
1995 Genesis Amtran automatic transmission converstion
We need some help converting from Auto to standard transmission on a 1995 Amtran Genesis International bus.
tmckinney is offline   Reply With Quote
Old 05-03-2014, 09:39 AM   #2
Engine: 190hp 5.9 Cummins
Re: 1995 Genesis Amtran automatic transmission converstion
Wow, it's going to be a pile of work.
What part do you need help with?
Why do you want a auto? Did the standard wear out?
Where do we even start?
Old 05-06-2014, 08:42 AM   #3
The Automatic transmission is causing the engine to get hot. I want to convert to standard transmission but cannot find any manuals for this bus.
Old 05-06-2014, 09:24 AM   #4
frank-id's Avatar
before changing the trans
Some testing is in order. Get another temp sender the same as the engine uses. Connect the new sender into the auto trans cooling lines. Connect a single pole double throw toggle switch. Connect the switch center connection to the gage, connect the temp senders to the outer connections. This gage wiring will allow viewing both the temps of the engine and trans and to decide
Where the heat, if any is coming. Transmissions only create heat while under a heavy load pulling up a very steep mountain.
It is also important to check the trans fluid color. Shiny red is great as dark red or brown means the fluid needs changing. An auto trans does better shifting than a manual trans............Frank
Old 05-06-2014, 10:01 AM   #5
You will not find a manual to convert a bus from a auto to a standard trans anywhere. You just need automotive back ground knowledge.
You need to learn your entire bus inside out. Learn about your auto trans, what rpm it needs for full band pressure, what model it is, whether it has a locking converter or not, ect.
Learn about the trans fluid to coolant heat exchanger, consider using a external trans cooler, ect.
There is no easy fix here. You need to know everything that makes your bus work.
Or just buy a bus with a standard trans, and wait for the next thing to brake down that you know nothing about.
And be sure to check the things that frank mentioned.
Old 05-28-2014, 05:07 PM   #6
Chassis: International 1753
Engine: 6.9 International
Your sure the auto trans is causing the engine to get hot? I've heard of strange things happening but your trans fluid temp would have to be out of this world in order to pull something like that off. Unless your engine is out tune or you have bad thermostats I just can't foresee something like that happening. Like what frank-id said, your automatic transmission will really only generate a significant amount of heat when you are putting a heavy load on it, lugging the rpm down would exacerbate this too because of the decrease in flow and pressure. But even then I would think it would puke out all the trans fluid and seize up solid before it would cause the motor to overheat, unless the engine was already prone to overheating and the trans added to it.
Old 05-21-2019, 10:16 PM   #7
Trans line fitting sizes
Adding the Derale inline trans cooler. Anyone know what size the fittings are on the trans~>radiator line so I can have my local shop make them? I’ve looked everywhere to no avail.
BCreten is offline   Reply With Quote
Old 05-25-2019, 08:46 AM   #8
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
I think he meant he can’t find any manual transmissions for his bus.
Edit: reply meant for nat_ster
WARGEAR is offline   Reply With Quote
Old 05-25-2019, 12:36 PM   #9
I think natser been gone for years
Old 05-25-2019, 01:52 PM   #10
WARGEAR's Avatar
Dang I just saw that this thread is 5 years old!! My mistake ��
Old 05-25-2019, 02:22 PM   #11
Taking time to search and read old posts is a great way to get started. Kudos for making the effort.
Old 05-25-2019, 04:48 PM   #12
HazMatt's Avatar
Chassis: IH 3800, 8 window
Yup,
Last post dated Nov 28, 2015...
Genesis Amtran one in the same ? norreh1 International | Navistar Drivetrain 3 01-22-2014 11:43 PM
wtb Drivers front window for 1993 Amtran Genesis bhays Classifieds | Buy, Sell, Swap 3 11-26-2013 06:56 PM
1992 Amtran Genesis DT466 water pump replacement bryandavis International | Navistar Drivetrain 1 06-17-2011 06:23 PM
Automatic transmission swap fordsmoker55 GM | Chevrolet Drivetrain 7 03-04-2010 06:41 PM
Automatic Transmission Fluid Leaking wdbowers Conversion General Discussions 3 07-02-2008 10:17 PM
