Old 10-07-2011, 11:05 PM   #1
1995 international headlights
Haven't driven the bus at night since later winter. Tonight I strted the bus and the headlight don't turn on. When I try to turn them on all the other exterior running lghts come on but not the head lights. Is this a fuse ora headlamp problem? I can't find a fuse that is burned out...were is the fuses? what do I look for? could both headlight really be burned out a the same time?
purpleplaybus is offline   Reply With Quote
Old 10-08-2011, 12:11 PM   #2
frank-id's Avatar
headlights no work
The bus maker must be a Blue Bird. Blue Bird usually uses automatically reset circuit breakers located behind the switch panel. These breakers rarely go defective. To begin the search for the fault, remove a headlite and check the lamp. Next check would be the head lite switch. A simple test lite will work well for all the basic checks.......................Frank in Idaho
Headlights opus Classifieds | Buy, Sell, Swap 4 01-22-2014 02:27 PM
Headlights: One low beam out Dain Mechanical and Drivetrains 3 06-02-2011 08:04 PM
1995 Navistar International 3600 Repair and Service Manual Jay11030 International | Navistar Drivetrain 3 05-30-2011 10:43 PM
1995 International Thomas Billsman Short-Bus Conversion Projects 5 04-27-2008 09:17 PM
Daytime running headlights TomCat Conversion General Discussions 8 10-18-2007 07:38 PM
