02-25-2013, 07:38 PM
1999 BlueBird International - Rear Brakes
Does anyone know if they are drum or disk? I bought a bus and don't have it home yet and just curious to what it is. I haven't been able to find much info online.
Thanks
Chris
02-26-2013, 09:43 AM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: 1999 BlueBird International - Rear Brakes
Hmm, do you know if mine has drum brakes or not?
You won't get an answer the means anything without telling us more about the bus. Model, air brakes, how big the bus is?
02-26-2013, 09:44 AM
You won't an answer the means anything without telling us more about the bus. Model, air brakes, how big the bus is?
Yours has drum brakes CC
02-26-2013, 09:59 AM
Moderator
You don't know that. I didn't tell you what I have.
02-26-2013, 10:25 AM
you have a 1997 international with air brakes and it's from TN...so I guessed
you gave enough info
oh
.and you like long long walks on the beach with Tecate and limes and brief stops at Taco trucks
02-26-2013, 12:25 PM
Mines hydraulic brakes, DT466E engine, 1999, 3800, international, bluebird, 72 passenger
Hope that's enough info
02-26-2013, 01:01 PM
Not sure I googled "1999 3800 bus brakes" and all listings had air brakes, the drum brakes are more than strong enough for our needs
edited stupid air brake questions after looking at all your pics of inside and inder hood
EDITED after looking at your pics it is hydraulic thats why it has a hydralic master cylinder on it.
So I can give no further advice...I did try tho'
02-26-2013, 01:21 PM
03-04-2013, 12:38 PM
Its disk all the way around in case someone else needs this info.
