Old 05-12-2018, 11:20 PM   #1
7.3 powerstroke or T444
Looking at a bus and trying to figure out which it is (In theory I guess they're nearly identical)
it's a 99 international. Sticker on valve cover says 7.3L DI Turbo Diesel Navistar.
vin: 1hvbbabp1xh202340
Really still wanting a 466 but I'm getting tired of waiting too. It's been about 3 years.
pcdreams is offline   Reply With Quote
Old 05-13-2018, 12:39 AM   #2
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
The T444 is the 7.3 liter V8 Turbo Diesel built by Navistar.
The 7.3 Power Stroke was built by Navistar for Ford.
They are similar engines (built on the same base/platform), but are not the same.
Hope that helps....
johnbloem1974 is offline   Reply With Quote
Old 05-13-2018, 09:05 AM   #3
if its in an international bus / truck its a T-444E.
some ofthe differences between the 444E and the Poswerstroke 7.3
Navistar mechanical cam driven fuel pump. ford electric
camshaft is different (different high torque low RPM on navistar and fuel pump lobe)
head gasket on ford is thicker than on navistar (to handle RPM)
RPM limit (444E - 2700, ford - 3200)
horsepower curve on the 444E is set to lower high end HP but good low end torque..
electronics fords uses all different computers than navistar
Old 05-13-2018, 02:45 PM   #4
Johnny Mullet's Avatar
Engine: T444E 7.3L
I have the 7.3l T444E in my bus and don't have any complaints except it's slow, but I am fine with that. It's a great engine and pretty reliable.
Johnny Mullet is offline   Reply With Quote
Old 05-31-2018, 06:03 PM   #5
Year: '95
Coachwork: Thomas Vista
Chassis: International 3600
Engine: T444/at545
Rated Cap: 72? 11 window...
I know I'm a little late on this thread but I was in the same boat. Wanted dt466, settled for t444e.
Glad I did too, mpg's are awesome ($60 bucks from Waterloo Iowa to Milwaukee Wisconsin)
Runs at 65 mph floored on flat roads.
Acceleration is perfectly fine, I'm fairly light though.
Does definitely loose speed uphill, but not terrible.
xalv36963 is offline   Reply With Quote
Old 05-31-2018, 06:14 PM   #6
You feel it's better than the DT466?
Old 05-31-2018, 07:41 PM   #7
Dog Rescuer's Avatar
Engine: 7.3L 210HP Turbo Diesel T444E
Rated Cap: 28 + 3 wheel chairs.
I have the T444E 7.3l Turbo diesel - 210 HP (2000 International) - I love it. It will hit 75 mph (thanks to Christopher) - but runs really nicely at 55 / 60 mph - getting about 10.5 MPG around the mountains of Montana - decent power - I have no complaints towing my Subaru.
I am rarely in a hurry to get somewhere - so there is no need to push it. I am all about enjoying the drive.
It seems to have been geared nicely for mountain driving - so I have solid power when I need it.
- Roger (Dog.Rescuer)
Dog Rescuer is offline   Reply With Quote
Old 06-17-2018, 05:50 PM   #8
So, prey tell...what did Christopher do or suggest that you are happy with?
as I have the same bus and I'm just a newbie looking to learn what would be best for me to try and do for her
hapicampr is offline   Reply With Quote
Old 06-17-2018, 05:57 PM   #9
brokedown's Avatar
Chassis: TC2000 FE
Engine: Cummins 5.9
Christopher likely upped the electric speed limiter, he did the same on my bus.. He also enabled my cruise control (Thanks!) but to be honest the speed limit increase only matters going down hills!
Keep up with us and our build!
Follow us on Facebook, Instagram, YouTube, and Twitter
brokedown is offline   Reply With Quote
Old 06-17-2018, 08:03 PM   #10
That is very true - I rarely get to 60mph except going downhill!
Old 07-15-2018, 11:38 PM   #11
Coachwork: international
Chassis: blue bird t444e 6 window at545
Engine: 7.3 international
what gear do you have in the rear axle and what did christopher do to make it better
burley bus is offline   Reply With Quote
Old 07-15-2018, 11:51 PM   #12
I have no idea what the rear gear is - Christopher just open the speed control from 65 to 80 - which has helped.
Old 07-16-2018, 07:09 AM   #13
I remember when we looked at oyurs i was thinking it is the ideal gearing.. you have the allison 2000 Overdrive trans.. and i thought a 4.44 gear? to me that bus has the ideal setup for a 444E drivetrain.. I dont think I saved a snapshot of your computer, if i did i priobably emailed or texted it to you.
