Old 09-04-2019, 11:06 AM   #1
AC leak...
OK so my 97 international blue bird bus has and AC leak... I found the leak but for the life of me I have never seen a more getto rigged system. I have have NEVER seen an AC line with a HOSE CLAMP! And that's where my leak is... WTF do I do about it?!
Necro is offline   Reply With Quote
Old 09-04-2019, 11:09 AM   #2
That's where the leak is. You can even tell it's a little wet
Old 09-04-2019, 11:24 AM   #3
looks like that got too close to the turbo and likelty they cut a section out and spliced it..
you can get a crimp splice for that line and then I believe the loan-a-tool from auto zone for A/C line crimp..
Old 09-04-2019, 05:59 PM   #4
NOPE! Every AC line on here looks like that. Even the ones that aren't leaking...
Old 09-04-2019, 06:15 PM   #5
I used to see this in R12 systems but never on 134a unless it was a total half ass job..
Old 09-04-2019, 06:33 PM   #6
Coachwork: American Cargo 14'L x 7'8"W x 7'H Box
Chassis: Ford E350 Cutaway
Rated Cap: 11500 lbs
Where are you located? I have the crimping tool and plenty of hoses.
alpine44 is offline   Reply With Quote
Old 09-04-2019, 07:03 PM   #7
Trinity, Tx
Old 09-05-2019, 11:38 AM   #8
Hey Christopher,
I have a related question :
My truck has a minor leak in the A/C. The last couple of summers I have needed to add 1-2 small cans of refrigerant t get the A/C to cool properly. Should I be concerned about adding too much oil doing this?
Thanks.
S.
Old 09-05-2019, 11:43 AM   #9
Hey Christopher,
Thanks.
S.
as long as you buy the plain cans you will be fine.. unless you see a noticeable oil splotch on the condensor or lines.. then every few years you can add a can that also contains oil.. only ever add one can of 134A that contains dye or stop leak.. otherwise just plain 134a doesnt contain oil.. and never buy the cans that say "enhanced for colder air".. theres an additive in there they claim makes it colder.. im not convinced it isnt a non-condensable..
eventually the leak will get bigger and you can find it and fix it.. until then you can add.. just dont over-charge it to try and get it to "last all year" or such..
Old 09-05-2019, 12:04 PM   #10
Thank you.
I may break down and take it to the shop. I have had a UV leak Finding kit in my Amazon wish list for almost two years..... I keep procrastinating....
