Old 03-11-2018, 05:02 PM   #1
Engine: International t444e
Rated Cap: 66?
Advice/Insights needed - replacing air compressor
Hi people
I have a 1998 International 3800 with the t444e (7.3 Navistar).
I have to replace the air compressor, which is a Bendix Tu-Flo 550.
It seems pretty straightforward, but because I've not done this before I thought I would toss it out to those of you with more experience and technical knowhow so that I don't overlook anything.
Other than the air connections it looks like it has 2 connections for coolant to the head and 2 connections for oil (transmission fluid?) to the crankshaft. I plan to plug these with something (any suggestions?) while I work on it.
The pully seems to be held on by a nut, so that should be easy enough, right?
I will need to buy or borrow a socket for the 4 bolts holding the compressor to the plate under it. Can anyone tell me what this type of head is called? (see picture)
Finally, what gaskets might I need? It seems to me that the only one is at the air intake since this is a belt-driven unit.
I really appreciate any help.
Gary
ghodges is offline   Reply With Quote
Old 03-11-2018, 06:40 PM   #2
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
You just need a 12 point socket for that capscrew.
Sent from my SM-G920V using Tapatalk
wunderhut is offline   Reply With Quote
Old 03-11-2018, 10:05 PM   #3
Dog Rescuer's Avatar
Engine: 7.3L 210HP Turbo Diesel T444E
Rated Cap: 28 + 3 wheel chairs.
I replaced the seals on my Air compressor. I am not sure why I did it - I think they were leaking a little.
There is a seal kit.
https://smile.amazon.com/INTERCHANGE..._&dpSrc=detail
I ordered that - and a friend pulled the thing apart and changed them.
I wish I could remember the bits he used - because I know I didn't have the one he needed.
We used locking vise grips to stop the coolant lines.
If you stop by any diesel mechanic - or truck stop - they should be able and willing to show you what you would need to do it. I have had a lot of luck with that.
I hope that helps a bit!
- Roger (Dog.Rescuer)
Dog Rescuer is offline   Reply With Quote
Old 03-12-2018, 07:32 AM   #4
Rated Cap: 66?
Ah, thanks, wunderhut
Old 03-12-2018, 07:35 AM   #5
Rated Cap: 66?
Thanks, Roger. I appreciate that.
air brakes, air compressor, international 3800
