Old 02-18-2019, 09:39 AM   #51
Rogue1bus's Avatar
PS. I guess some of these other plugs on the bus side could be for reverse lights/beepers etc. That one large 8 pin plug is still puzzling me.
Rogue1bus is offline   Reply With Quote
Old 02-18-2019, 12:55 PM   #52
Rogue1bus's Avatar
I talked to the international dealer and gave them the harness part number.
They told me the harness is compatible with 3200 series buses that were equipped with dt466 engines.
I have a bluefire j1939 code reader so Iím feeling pretty confident I will be able to make this harness work despite it being designed or a different engine.
Old 02-19-2019, 03:00 PM   #53
Rogue1bus's Avatar
I ordered the wiring harness today. Hopefully Iíll be able to get it to interface with my t444e.
This Iím my TCM, Iím banking on my ECU being capable of sending throttle info to the TCM... if not Iíll need to find a work around.
Old 02-19-2019, 04:14 PM   #54
Your throttle will send from that 3 pin connector I described, you need to reprogram the ECM to make the Speedo and cruise work correctly and not throw codes.
Christopher
Old 02-19-2019, 04:18 PM   #55
Iíll have to see if my oncommand has the pinouts for all those connectors, it should since it covers those years. You may have to add some wiring in the chassis side as it may not be there by default.
Christopher
Old 04-11-2019, 05:56 PM   #56
Chassis: Integrated CE S
Originally Posted by Rogue1bus View Post
Chesapeake and Newport News va
Rogue,
What scrap yard(s) did you go to? I'll likely be trying to poke around some scrap yards if not just for fun.
Build thread: http://www.skoolie.net/forums/f11/bus-down-by-the-river-26371.html
inhof009 is offline   Reply With Quote
Old 04-11-2019, 06:45 PM   #57
Rogue1bus's Avatar
Originally Posted by inhof009 View Post
Rogue,
Rudyís!
