Old 05-14-2016, 09:40 PM   #21
2kool4skool's Avatar
First trip with new ATF. The 545 loves the new oil. No 1st to 2nd squeal and overall nicer shifting.
Walmart Supertech Dex 3
Don, Mary and Spooky the cat.
Old 05-14-2016, 11:29 PM   #22
Robin97396's Avatar
Nice. Is that one of the imitation syntech fluids?
Do you do anything about the fluid in the converter when you change fluids, or just let it mix?
Old 05-15-2016, 09:11 AM   #23
Originally Posted by Robin97396 View Post
Nice. Is that one of the imitation syntech fluids? Just Dexron 3, what it calls for.
Do you do anything about the fluid in the converter when you change fluids, or just let it mix? I drained after sitting for a couple days, most of oil is in the trans at that point.
Old 05-15-2016, 09:47 AM   #24
I dont know how it would do on a 545 but on my old cars I always "spun" it out.. id drop the pan, pull the filter.. and then start the engine for about 5 seconds and it would spin the converter dry without running the pump long enough for any damage to occur.. I used to get quite a bit of fluid dropping out that way..
