Originally Posted by Jolly Roger
Did you figure out anything on your 545 temp. Sensor? I would like to add one to mine.
I know the sensor on the right hand side/passenger/door side is for the backup lights and my 86 was a pressure switch but yours might be electronic.
not yet, i found a connector under there with 2 pins on it not taped over so im guessing it may be where a sensor was.. it looks liek the transmission was changed with a rebuilt unit at some point.. theres whats left of a tag on the side that has the start of a transmission shop name so they may not have replaced the sensor.. alot of 545's dodnt have them.. or maybe the sensor leaked and they capped it..
the lastest ive found is the sensors go in the pan on other allisons and i have a couple plugged bosses in the side of my pan so I can guess thats where the sensor goes..
my next move is to call IHC and see if they can look a temp sensor up by VIN.. since the dash panel has a gauge on it, theres a good chance i can get a part number for it
