Old 02-13-2014, 03:56 PM   #11
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Block heater questions
When I've had diesel vehicles with block heaters that I used to commute to work, I plugged them in to a timer so it would activate a couple hours before I had to start the vehicle. Worked like a charm. It is a good feeling to have your diesel instantly come to life and purr when it's freezing outside. I really dislike the sound of a loudly clacking frigidly cold diesel engine.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 05-27-2014, 10:06 AM   #12
Chassis: International 1753
Engine: 6.9 International
We've always plugged them in around freezing(32*F or 0*C). Cold weather is hard on diesel engines and bearing and cylinder wall wear go down tremendously by using the block heater. You won't ruin the heater by plugging it in above that temp but the benefits aren't as well noticed. The current draw depends on the wattage of the heater. Most are around 1000-1500 watts which is pulling about 10 to 15 amps.
Old 01-28-2017, 12:26 PM   #13
rjnye79's Avatar
Engine: T444e
I have this plug on my bus, near the entry way. I'm assuming that means a block heater is already installed. If so, what type of cable do I need to use it?
Sent from my VS930 4G using Tapatalk
rjnye79 is offline   Reply With Quote
Old 01-28-2017, 12:30 PM   #14
Originally Posted by rjnye79 View Post
Attachment 12118
I've typically seen this style...
But, I've also seen just a good quality extension cord female end work also.
Old 01-28-2017, 12:32 PM   #15
rjnye79's Avatar
Engine: T444e
Thanks. That's pretty much what I thought. Is that typically a 13 or 15 amp cord... or more?
Old 01-28-2017, 12:33 PM   #16
roach711's Avatar
Rated Cap: 19
Attachment 12118
We'll need to see a picture of the receptacle prongs to make an intelligent guess on the cable, and remember what assume does to U and ME.
The Roach Motel
Old 01-28-2017, 12:33 PM   #17
Since this discussion is about block heaters.... (I don't have one)
Are they a passive element that's installed in the water passage? I'm picturing something like a water heater element or one of those charcoal lighter coils.
Or a pump & element installed in the radiator hose?
Old 01-28-2017, 12:40 PM   #18
I like this guy's use of an old computer power supply port & cable....
Most everyone has these in the junk drawer???
Old 01-28-2017, 06:24 PM   #19
Engine: Navistar 7.6L
I believe most all O.E.M. engine heaters are a heating element installed in place of one block expansion plug.
Most of the aftermarket ones are in one heater hose. And still uses the immersed heating element.
Both will be no more than 1800 watts @ 120v because most household plug in circuits are 15 or 20 amps.
I prefer the heater hose version because it will push heat throughout the engine eventually. Whereas the in block heater heats the immediate where installed.
DoubleO7 is offline   Reply With Quote
DIY Heater for a Small Space: pulse jet heater lornaschinske Everything Else | General Skoolie Discussions 8 07-15-2012 08:54 PM
cant find block heater putterspitt Conversion General Discussions 4 12-14-2010 06:54 PM
New kid on the block Stan Everything Else | General Skoolie Discussions 7 05-14-2008 07:59 AM
cabin heater cores and framing questions the_experience03 Conversion General Discussions 5 07-31-2007 09:45 PM
Block Heater Safety Issues? Steve Conversion General Discussions 1 06-29-2004 12:15 PM
