Old 10-08-2018, 09:49 PM   #1
Rogue1bus's Avatar
Bluetooth OBDII to j1708/j1939
I got an cable adapter from amazon so I can connect my Bluetooth OBDII reader to my 2002 AmTran t444 skoolie. I can connect fine via Bluetooth but none of my apps can read the j1708/j1939 protocol.
I did a lot of searching and canít find the info I need....
Has anyone been able to rig a (preferably low cost) solution to read codes and engine data on a phone or tablet like we can on other OBDII vehicles? Seems like I have the hardware I need, I just need an app that can understand truck/bus protocol..
Thanks!
Rogue1bus is offline   Reply With Quote
Old 10-08-2018, 11:02 PM   #2
Perhaps this is what you are looking for : https://bluefire-llc.com/trucks.html
PNW_Steve is online now   Reply With Quote
Old 10-09-2018, 06:57 AM   #3
Bluefire is an up and coming out of the box solution that seems pretty promising..
Scangauge D is another one that can read data from the 1708 / 1939.
or you can do a mixture of commercial and Build your own..
Old 10-09-2018, 07:34 AM   #4
Rogue1bus's Avatar
Attachment 26347
That look amazing!
Can you elaborate a little more on in the overall concept of building your own and mixing components?
Old 10-09-2018, 09:00 AM   #5
brokedown's Avatar
I put the scangauge d on my short bus and it's good for adding basic info that might be missing from your dashboard. I set mine to monitor boost, voltage, coolant temp, and average MPG. It can also pull and clear codes and do things like track your cost per mile if you plug in your fillups.
Old 10-09-2018, 10:27 AM   #6
A warning...Cadillac is the McGyver of Skoolies. He can build a supercomputer/gaming system out of three paperclips, an empty paper towel roll and a 9v battery!
Old 10-09-2018, 11:30 AM   #7
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
I second the bluefire adapter as I have one (6-pin, J1708-only). I'd like the software that comes with it to be a bit more flexible, but that will come in time.
I also have a scangauge D. I second the idea that it "adds basic info missing from the dashboard". All the info that I've become accustomed to on my cars is available on the scangauge D, but be warned that its display is not the easiest to see. Its probably best as a "trip" computer that you consult at fillups or other times when you aren't driving.
I also second the concept that cadallackid is the MacGyver of skoolies.
See https://j1587scanner.blogspot.com/20...anner-for.html as it is my inspiration for my components listed below....
Deutch 6-pin J1708 connector:
https://www.ocp.com/j1708/
Copperhill Technologies J1708-to-UART adapter (not available yet, but don't want to build my own modified-RS-485 interface):
https://copperhilltech.com/blog/unde...edded-systems/
ELM325 J1708/J1587 interpreter:
https://www.elmelectronics.com/ic/elm325/
ARM-based, credit-card sized Linux computer:
https://www.raspberrypi.org/
Note that if you want to interface to your laptop, then you'll need a TTL-UART-to-USB interface. Sorry, I don't have a link for one of those handy.
EDIT: https://copperhilltech.com/ft232-usb-micro-uart-board/
Also note that I have no power circuitry listed here - still working on things....
MarkyDee is offline   Reply With Quote
Old 10-09-2018, 12:18 PM   #8
Markydee hit it right.. I have a;; the stiuff he describes.. plus some of these..
https://buy.advantech-bb.com/Product...ID=BB-HDV100A3
I have this copperhill board.
https://copperhilltech.com/sae-j1939...with-usb-port/
it is not just an ECU SIM it can also read / write J1939.
part of my work was for the digital dash but also to improve engine to transmission communications.. if your engine has the provisions (or has) an electronic transmission.. (CAT-3126, C7, T-444E, DT-466E, ISB 24 valve, ISC) then you also have J1939 onboard htat usually sends all availabl;e engine parameters.. I find that Navistar sends a good amount of data over this.. J1708 and J1939 are physically different.. my digital dash is using both links..
plus im taking and translating the data for better shifting.. ie using engine loading, time, real throttle, cruise desired speed, cruiise actual speed, etc .. to help the TCM decide which gear to put the allison in..
Not all info I want is in the stream.. thus the Raspberry pi so I can take temperatures, pressures, etc and put them on the displays... im just getting started.. time has been short this year so i havent had as much time to really dive in like ive wanted.. most weeks im working 7 days.. i havent even gotten to road trip as much as usual.. work . business is in High gear.. dont believe anyone who says "business owners are lazy with their feet on the desk all the time".. it aint true. heck I havent even had time to go rent me in apartment in florida for the winter.. but then its still been summer in ohio so no need yet..
if you are wanting to write your own code and talk to the J1708 on your own on the cheap, the ELM325 that Markydee linked to is THE way to go.. its by far the best total DIY for the electronics / software hobbyist to get going.. next in line the BB-electronics deivce has a VERY easy protocol. and no soldering needed but it $$$ more.. those will talk both 1708 and 1939. and give it to you in different formats..
if you check out my 'RedByrd Transformation' thread in short busses I did a little bit of GeekSpeak with a sample code snippet to read and parse the J1939 with very common PHP-CLI.
Old 10-10-2018, 05:06 PM   #9
Rogue1bus's Avatar
Thanks for all the great info! I definitely may delve into this kind of project alittle further in the future. I just donít have the time to commit while Iím trying to pound out the actual conversation. Itís really interesting stuff though. So I pulled the trigger on the bluefire system for now since my cluster gauges quit a couple of times ( I think I fixed it with some cleaning, dielectric grease and a slim). The cost is alittle high but I need to be able monitor engine/transmission parameters so I donít cause any major damages. And the scan gauge cord wonít reach the plug in the back of the bus...
I think in a couple of years I may try and switch my 545 tranny to an Allison 2000, which should be a direct bolt up procedure for a shop. Problem is I will need to workout the electronic communications with my t444e to get it to work.
Is the coding your talking about the same sort that will allow me to program my t444e to work with a different transmission?
Thanks again
Old 01-14-2019, 03:13 PM   #10
Coachwork: IC BUS
Ever think about doing a write up and sharing the code when it's done?
X2Kawa is offline   Reply With Quote
