Old 02-14-2017, 07:07 PM   #1
sojourner's Avatar
Engine: DT408
Brakes for 1995 AMTRAN
Got a question on brakes that someone might be able to answer.
Looking at the lineset of our bus (VIN# 4DRGSACN9SA06341) I see these designations on the brakes:
04 N04B 0004161 BRAKES, FRT AIR CAM 16.5 X 5 Q
04 N04C 0004273 REAR BRAKES, AIR CAM 16.5"X7" W/30 SQ IN MGM SPRING ACTUATED
The Axles are as follows:
02 N02A 0002ADE FRONT AXLE 1-BEAM TYPE 14,000 LB CAPACITY
14 N14A 0014ADC REAR AXLE, SGL(INTL N-190) SGL REDUCTION 19,000 LB CAPACITY
I'm trying to find the correct brake kits to service the brakes. I want to make sure I order the correct set since I'm 600 miles away from the project and want to get everything sent in so I can work on it while back home. Where can I get the numbers for the kits with some assurance I have the correct numbers? I've tried two different International dealers and none of them will return my emails or phone calls. Frustrating!!
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 02-15-2017, 09:15 AM   #2
Chassis: International 1753
Engine: 6.9 International
The only place that will get you that stuff would be a dealer with 100% certainty is a dealer. Are you trying an actual bus dealership or are you trying a regular international dealer?
Most places would be able to get the parts but they'll have to have it in front of them to order.
Try Carolina Bus Sales (864) 461-7088, Not sure how close they are to you but they should be able to get you what you want from the info you have.
