Old 08-01-2018, 11:50 AM   #1
Can you tell transmission type from Vin?
I found a 99 3800 with a 466e. I was wondering how to tell which trans is in it. I have the vin number, the owner told me it was a 4 speed
Badbus81 is offline   Reply With Quote
Old 08-01-2018, 12:04 PM   #2
If you call International and give them the vin they can tell you.
The online decoders will not give transmission info.
Old 08-01-2018, 12:07 PM   #3
Ok appreciate it
Old 08-10-2018, 11:15 PM   #4
What's your VIN? I know a guy.
More Power is offline   Reply With Quote
Old 08-11-2018, 01:02 AM   #5
1HVBBAAP5XH206229 , thanks
Old 08-11-2018, 11:05 PM   #6
It was originally built with an allison at545 4-speed automatic
Old 08-12-2018, 12:11 AM   #7
Crap. I don’t ever hear anything good about those. Thanks!
Old 09-29-2018, 07:40 AM   #8
Chassis: Amtran
hI,
Can you tell me what transmission mine is and what HP rating the motor is?
Thanks,
Michael Callahan
1HVBGAAR61A916128
Cdimples67 is offline   Reply With Quote
Old 09-29-2018, 10:11 AM   #9
Originally Posted by Cdimples67 View Post
hI,
Thanks,
Michael Callahan
1HVBGAAR61A916128
Michael 1HVBGAAR61A916128 was built with an international dt466 with 215 hp @ 2400 rpm's & 620 lb-ft tq @ 1400 rpm's. Trans is allison md 3060 5-sp without pto gear or retarder.
Old 09-29-2018, 12:44 PM   #10
hI,
Thanks,
Michael Callahan
1HVBGAAR61A916128
You got the good tranny with 6 speeds even though it has only 5 open now. Follow the unlock threads to see how you can gain the extra overdrive and save in fuel economy.
Old 09-30-2018, 07:55 AM   #11
Exactlywhat I try to understand as well, would be great if someone could tell me the transmission and maybe rear axle for VIN 1HVBBABL8TH301339.
Many thanks in advance and cheers Volker
Damdy-Cash is offline   Reply With Quote
Old 09-30-2018, 08:29 AM   #12
Chassis: Amtran
Thanks guys!!! I really appreciate the info, I am getting ready to start towing my jeep and was hoping the trans was a good one
Old 09-30-2018, 08:31 AM   #13
Chassis: Amtran
I will do some reading about unlocking it thanks, do you know if the HP can be increased without changing anything mechanically?
Old 09-30-2018, 12:08 PM   #14
Often VIN decoder/build sheets will not list the specific tranny in them. you have an 1996 International 3800, Navistar 444/V8, air brakes, made in Springfield ,Ohio. You need to run the VIN on the chassis for the tranny info.
Old 09-30-2018, 02:20 PM   #15
Will see the bus on wednesday and check, do you know where about at the chassis is it locate? Also the tranny should have a plate somewhere thought? Cheers Volker
Old 10-03-2018, 12:56 PM   #16
So its a AT545... . The only information Im still try to find is the diff ratio. Is that something the VIN is telling? Btw found a VIN on the chassis but it is actuall the same as on the plates. Cheers Volker
Old 10-03-2018, 01:04 PM   #17
brokedown's Avatar
Axle ratio should be on a badge above the windshield.
Old 10-03-2018, 01:07 PM   #18
I've not had one yet with that, but I've seen it on Bluebirds I think.
My axles all have the ratio on the housing on a tag.
Roll Your Own Build Thread
Old 10-03-2018, 01:13 PM   #19
Some good tranny, engine, gear info.
Engines & Transmissions — Buslandia
Old 10-03-2018, 02:37 PM   #20
brokedown's Avatar
Seems I mis-remembered my Thomas having that tag inside!
