Old 02-21-2011, 11:37 PM   #1
frank-id's Avatar
Re: cant start my 91 international.
Greetings. I also have a 1991 International bus by Blue Bird. My bus has a 7.3 L diesel engine. To the best of my experiences, all buses of this era use an ignition key/lock system. The only push button that I know of, is the push to release for the air brakes. To release the brakes, the engine needs to run to pump up the air brake system to about 70 psi. ..... Frank
Old 02-22-2011, 03:21 AM   #2
Year: 92
Coachwork: ward flat nose
Chassis: international
Engine: dt466 mt643 air ride
Re: cant start my 91 international. how to push in "engine s
Try turning the 'stop engine' knob 90 or 180 degrees, and see if you can get it started in that way. Sounds as if you pulled the cable out too far. Otherwise you may have to dis-connect the cable at the injector pump and try to reinsert the handle side into its sleeve, and then reconnect the cable on the pump side. Once you do that a few times, you'll remember not to pull it out too far. Hopes this helps
kotflb is offline   Reply With Quote
1990 International - "Moby Dick" npeace Skoolie Conversion Projects 8 09-11-2016 06:46 PM
Start of my "new" bus build SitkaConvert Short-Bus Conversion Projects 37 10-05-2014 03:28 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 01:19 PM
1993 International "Brick" toyhauler gotmuddy Skoolie Conversion Projects 5 05-03-2009 03:34 PM
Diesel "Runaways" and other failures to stop KevinCoughlin Conversion General Discussions 3 08-29-2007 09:49 PM
