Old 01-05-2018, 08:09 PM   #1
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
Crapped out?
Well, crap. Was about 5 min from Skooliepalooza and the tranny seems to have cratered out. Didn't want to shift from 3rd to 4th, then basically went out of gear and I coasted off the side of the road. Now it will not go into any gear. Any ideas? I looked underneath and everything looked normal. I had my wife move the shift lever and I could see the linkage moving on the side of the transmission.
1998 DT466E with AT545
Sent from my SM-G950U using Tapatalk
johnbloem1974 is online now   Reply With Quote
Old 01-05-2018, 08:47 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Dang. Nothing, huh? no grinding or engaging at all? You think it's the converter pump?
Old 01-05-2018, 09:12 PM   #3
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
I don't know enough to be of a help other than I remember on one of my cars if the transmission level was low it would not shift properly.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 01-05-2018, 09:19 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Fluid level?
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 01-05-2018, 09:19 PM   #5
Rated Cap: 16
Unfortunately, I don't know enough about transmissions to answer that....
Old 01-05-2018, 09:20 PM   #6
Rated Cap: 16
But no grinding or engaging. Move the shift lever and nothing happens at all.
Old 01-05-2018, 09:38 PM   #7
Chassis: Saf-T-Liner MVP ER
When that happened to our Ford Taurus the splined shaft that drives the pump had given up ... wear in the splined bit of the torque-convertor.
Everything worked just fine, but the car wouldn't move.
Unfortunately, it was transmission out to fix it.
Steve Bracken
Build Thread
Old 01-05-2018, 09:48 PM   #8
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Engine: 5.9L 24V-L6 Cummings ISB
Rated Cap: 26 foot
You really need to find the transmission dipstick (rear passenger side of motor on my AT545 with a Cummings). Check the level with the motor running, transmission in park. Pull it out, wipe it off, put it back in, and pull it back out and check the level. It may take several tries. Look at both sides of the dipstick. Pulling it out draws fluid up into the dipstick tube, and will make it look fuller that it really is, after the first time you pull it. Wait a minute or two after pulling it, then re-insert it and pull it again to check the level.
If the fluid is low, add more. If it is black or clear and thin, you need new fluid (along with a new filter). The fluid should be cherry red when in good condition.
Old 01-05-2018, 11:14 PM   #9
Rated Cap: 16
Fluid looked OK. Nice and reddish-pink, didn't smell burnt. Level didn't seem too low. One weird thing is that neither the reverse lights nor the alarm beep goes off when you put it in R.
Just got it towed to a shop in Quartzsite, but they don't open until Monday... at least we have the car and can go hang out...
Old 01-05-2018, 11:17 PM   #10
I hate having to call a tow!
Wishing you all the best of luck!!!! You're two of my favorite folks on here!
Roll Your Own Build Thread
