Old 05-20-2019, 10:24 PM   #1
Cruise control does not work
IC CE300,2005, dt466e enging, alison tranny, 206k
Hi. Cruise does not work. No lights come on on the 2 buttons. Does any one know how to fix this? thank you
pratokko is offline   Reply With Quote
Old 05-21-2019, 06:25 AM   #2
You need a special link and some software. You go into the computer and enable cruise.
A dealer will do it for free sometimes.
Roll Your Own Build Thread
Old 05-21-2019, 07:04 AM   #3
the cruise may be disabled in the computer as ECCB says.. the buttons do not light up even when cruise is enabled and active..
also note that the cruise on/off button appears "backwards".. you need to push in the bottom of the on/oiff switch to turn it ON.. which seems backwards...
Old 05-21-2019, 07:24 AM   #4
HazMatt's Avatar
Chassis: IH 3800, 8 window
That might be it:
Cruise only works when the tranny's in Reverse...
Old 05-21-2019, 07:27 AM   #5
Originally Posted by haz.matt.1960 View Post
That might be it:
ha!! if you can drive a bus at the minimum, set speed of 35 in reverse I want to come and watch!
Old 05-21-2019, 07:33 AM   #6
HazMatt's Avatar
Yee-HAW!!! 🤠
