Old 01-08-2015, 05:04 PM   #1
Dead short?
I own a 1996 Thomas with a intl. 7.3l diesel. I went to start it the other day and the batteries were dead. As they were 3 years old I replaced them and the engine started right up. THEN I noticed the ammeters showing a minus charge. The weather allowed me to go back out with my multi meter today to start doing voltage checks and the batteries are dead. I'm guessing a dead short but where in the world do you start?
dennyp2949 is offline   Reply With Quote
Old 01-08-2015, 07:00 PM   #2
Coachwork: Honey Badger RV Co
Chassis: tc2000
Engine: 5.9 cummins
Rated Cap: 74
Alternator. They can charge great and discharge just as well if the armature in grounding out.
wauto is offline   Reply With Quote
Old 01-08-2015, 07:24 PM   #3
Any idea how or why the alternator would/could do that? Could I do a continuity check with my multi-meter, armature to ground to check for it? Thanks Wauto
Old 01-08-2015, 09:26 PM   #4
"Dead short" implies no resistance at all. If so, all the wires would be cherry red and too hot to touch. You do not have a "dead short" or the bus would be on fire.
But, you do have something drawing down the batteries. It could be some electrical device that does not go off with the key, or it could be some kind of failure. If you see a negative charge when the engine is running, either the alternator is not working, or whatever the draw is takes more electricity than the alternator can put out.
If you have a portable ammeter with the capacity to take the current of the bus batteries, you could make some tests. If you have a standard hand held multi-meter that only takes a fraction or a couple of amps, you will need a shunt resistor to measure the amperage as voltage drop across it. The easy way would be to use a DC-rated clamp-on meter that clips around the wires and measures the magnetic field.
To test the alternator, put the clamp-on around the output wire, or disconnect the output wire and put the ammeter or shunt in line between the alternator post and the wire you removed. If the alternator draws voltage from the battery with the engine off, it is bad. With external diodes on a high-capacity alternator, perform the test between the battery wire and the diode pack.
To find an unknown draw, put the clamp-on around the hot or cold battery wires, or else disconnect either the hot or the ground wires from the batteries so there is no power to the bus. Put the ammeter or shunt in line between the disconnected wire and the batteries. If there is current showing, the troubleshooting method is to disconnect wiring to the bus's devices one at a time until the meter reads zero. If you have a radio with a clock and station presets, there may be a fraction of an amp drawn all the time for those.
As far as poor alternator output, there are several factors to be measured, the output voltage, the output current, and the load current. If the load is excessive, the voltage will show low and the alternator will appear to have no output when it actually is working as hard as it can. This might be a reason for the discharge on the ammeter if there is a problem draw somewhere. A clamp-on around the output wire would confirm any current coming out. Testing with an in-line meter and the engine running is a bit hard.
If the regulator or alternator are defective, there could be low voltage with little to no load. This too would show the discharge as the batteries and not the alternator are powering the bus.
The other possibility is a bad connection somewhere. We had an almost-new Mercedes/Freightliner that stopped charging, and ran the batteries down to the point that the Allison transmission stopped shifting. There was charging voltage at the alternator output, but none at the batteries. It turns out there was a binding post on the frame behind the fuel tanks where the heavy wires were all bolted together but not passing power between each other until the terminals were cleaned.
Electrical problems require detective work. Good luck.
Old 01-08-2015, 10:13 PM   #5
frank-id's Avatar
Chasing voltage
Disconnect the negative cable to the battery. Connect a test lite or horn between cable and battery. If there is any voltage anyplace, the lite will be on or the horn will beep. A motorcycle horn works great. When the voltage loss is found the lite will go out or the horn will be silent. First test is to disconnect all the alternator leads. Next is to slowly remove the fuses, one to next and watch lite. When lite goes out the fault is found......... Frank
Old 01-09-2015, 05:58 AM   #6
Did you replace both batteries at the same time?
If one battery is dead or bad, it will kill the other very quickly.
My bus had two dead batteries when I got it. The maintenance guy gave me a brand new one to get home on. it made it, but I had to get another new battery right away as the bus wasn't charging due to the bad one.
Rural King had group 31's for $70 a few weeks ago! I love that place.
