Old 06-14-2018, 02:39 PM   #1
Engine: DT 466 Mechanical spicer 6+1
Differential swap
I right now have a 96 int 3800 with a DT466 Mechanical engine that puts out 190 HP with a spicer 6+1 transmission and a rear ratio of 4.78. It does 68 redlined at about 2900 but was wondering if anyone would recommend a 4.10 rear end and if so what my RPMs would look like at 70 mph. Otherwise if not a 4.10 what other ratio? also just so you know, I will be pulling a 7X16 trailer behind it... thanks
alexzckary is offline   Reply With Quote
Old 06-14-2018, 03:25 PM   #2
2900 is HIGH for a DT. The lower powered ones redline at 2600, the high torque models redline at 2400.
Roll Your Own Build Thread
Old 06-14-2018, 04:17 PM   #3
Measure your tire diameter and plug the numbers in and you can play with different ratios, rpm and speed: Transmission Ratio RPM Calculator | Spicer Parts
