Yes, I did something similar. On the handicapped access door, I removed the automatic light switch and replaced it with a toggle. The buzzer was already disconnected when I got it, but the wiring bundle was still there over the drivers seat, along with other nonfunctional switches. I've removed the stop arm and disconnected all the flashers, capping off the wires that are now being removed. On the rear door, I previously removed the buzzer and taped the wires. As to the latches on both doors, I did something a little different: I drilled a hole through the tongues of the latches and inserted metal pins. That way, if you try the handle, it won't move.
