Old 11-09-2015, 02:55 PM   #1
Coachwork: AmTran (International)
Chassis: Gensis
Rated Cap: 74
DT 466 Engine need Radiator cap
I have a 1992 Amtran Gensis 46 passenger bus with a DT 466 engine. My radiator cap needs replacing but I did not know it is so hard to find what cap I need. Does anyone out there know what pressure cap I need? Or where I can get a cap?
Rodney
slager55 is offline   Reply With Quote
Old 11-09-2015, 03:36 PM   #2
Napa has them.
You must be out west, here on the east side they called them "Ward Senator" in 1992.
Old 11-09-2015, 03:39 PM   #3
Chassis: Gensis
Rated Cap: 74
Radiator cap Int'l Gensis DT 466
Bus parts.com got me the part number it is International part #530874-R1
and Orileys Auto parts has it for $7.49.
Thank you for helping
Old 11-09-2015, 05:32 PM   #4
Good to know.
They're fairly generic and readily available. I like stuff built like these buses.
Old 05-14-2016, 11:58 PM   #5
Coachwork: AmTran/Gensis
Quick question on a sort of related note. When adding coolant the other day, I accidentally pulled on what I believe to be the coolant overflow hose and it pulled the fitting out of the stem for the radiator. It appeared to just snap off right at the connection...suggestions on reconnecting? Can you solder this or JB weld or something? Thanks ahead of time for any suggestions.
jontettleton is offline   Reply With Quote
Old 05-15-2016, 12:30 AM   #6
Robin97396's Avatar
You should probably have someone solder that back on for you. It's a good thing you caught that, even accidentally. Imagine how bad that could have been on a trip. It shouldn't have pulled off that easily, unless you really smacked it. I think you just saved yourself a breakdown later.
Old 05-16-2016, 04:56 PM   #7
Chassis: International 1753
Engine: 6.9 International
Make sure it's not all corroded or too thin. You might have to solder on an entire new neck. If it is in good shape, a radiator shop should be able to reattach that pretty easily. If you do try to do it yourself, make sure everything is spotless in order to get a good attachment.
