Old 07-10-2018, 02:54 AM   #1
Engine: DT 466 Mechanical spicer 6+1. & 5.9 Cummins
DT 466 mechanical not starting
Hey so I know this is going to sound dumb so please keep the negative remarks to a minimum but I am new to this so any advice is appreciated. Anyway replaced the fuel filter on my DT466 and I didn’t put fuel in the filter, I tried starting it and sputtered but then loosened the filter to relieve pressure and tried it again and now nothing, how can I fix this issue?
alexzckary is offline   Reply With Quote
Old 07-10-2018, 05:16 AM   #2
Year: 1994
Engine: DT408 6.7L L6
My guess is prime the engine.
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
Old 07-11-2018, 11:15 PM   #3
help
how do I prime it?
Old 07-12-2018, 05:08 AM   #4
Year: 1994
On my DT408 the primer bulb is on the driver side of the engine block behind the fuel injection pump. My understanding is you push it until it becomes hard to push.
~Alf
My Build Thread!
Old 07-12-2018, 03:15 PM   #5
Got it going
What I ended up doing is loosening the injectors about a half a turn and cranked it till fuel started spraying out of them. I then tightened them back down and it started right up
