Old 05-10-2017, 05:15 PM   #1
Coachwork: AmTran (International)
Chassis: Gensis
Rated Cap: 74
DT 466 Wet sleeve removal ?
I need to remove my wet sleeves as I am doing a in frame overhaul but I cannot afford the expensive sleeve removers. Has anyone removed the wet sleeves using a more economical means? Please share with me how you did it or how I can do it. Thank you
slager55 is offline   Reply With Quote
Old 05-10-2017, 05:17 PM   #2
dmattarn's Avatar
Engine: DT466E Allison 3000
Rated Cap: 84 Kids/56 Adults
I've been thinking about buying just the plate for the OTC puller and then using a bar with a floor jack. Not sure if it will work and the plate is like 100 bucks.
Sent from my SM-G930V using Tapatalk
"Once you get it, you got it."
dmattarn is offline   Reply With Quote
Old 05-10-2017, 05:33 PM   #3
Chassis: Gensis
Rated Cap: 74
Thank you i will look into that
Old 05-10-2017, 09:20 PM   #4
Chassis: International FE
Rated Cap: 84 passengers
If you have access to some simple tools or a preferably a machine shop you could definitely make one. Just google homemade liner pullers and you'll get plenty of ideas.
DIY Liner Puller - TheDieselGarage.com
rensch26 is offline   Reply With Quote
Old 05-11-2017, 12:07 AM   #5
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I had thought about this when I was considering a 466.
I looked at some different types of sleeve pullers and one type was an expandable rubber sleave.
I had thought to try: a piece of thick walked rubber hose about 1/4 inch smaller than the bore with a steel circle at the top and bottom. Thread a piece of allthread through the bottom with a double lock nut at the top. As you turn the allthread it would squeeze the rubber out and grab the sleeve.
To extract: some sort of cradle that the rod would fit through and then use a nut/washer combo to turn it out.
It may not work, and I haven't tried it, but it was knocking around in my head after seeing something like it
Old 05-11-2017, 08:43 AM   #6
Chassis: Gensis
Rated Cap: 74
wet sleeve removal
Thank you all for your responses and ideas.
