Old 05-20-2019, 04:27 PM   #1
Clayton's Avatar
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
DT466 smoke troubleshoot
I own a skoolie that has a 1996 International DT466 230hp (mechanical) Diesel. Engine was overhauled but has not been broken in yet as it is not insured. Its been started and run now and then for a year. Since the rebuild I have had white smoke when I rev it up and sometimes an almost unnoticeable amount at idle. It runs and starts great. The injectors are a possibility but they were properly rebuilt at the Bosch dealer with new tips etc. I'm thinking either the rings are not seated, the injection pump is acting up, water in fuel? Any ideas from experienced members?
Clayton is offline   Reply With Quote
Old 05-20-2019, 04:37 PM   #2
Chassis: International 1753
Engine: 6.9 International
If you only have idle time, the rings are likely not seated yet. I wouldn't idle it anymore until you take it on the road. You can scuff a set of rings quickly if they're never seated.
Old 05-20-2019, 07:23 PM   #3
you need to take it out and drive it like you stole it..
Old 05-20-2019, 09:34 PM   #4
Clayton's Avatar
Thanks. Ill drive it as soon as possible.
Old 05-20-2019, 09:37 PM   #5
HazMatt's Avatar
Chassis: IH 3800, 8 window
Good advice.
Just don't get ticketed for uninsured along with speeding..! 🤞
