Old 05-02-2019, 12:21 AM   #1
Engine: 466e
Rated Cap: its Yuge
DT466e how to remove wiring harness from inside valve cover
Almost have my valve cover off and realized that there is a wire inside.
How do i go about removing the is so i can slide the valve cover off?
MambaJack is offline   Reply With Quote
Old 05-02-2019, 07:35 AM   #2
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
There's a wire bail on each connector at the injectors push it down and then unplug the connectors
Doe69936 is offline   Reply With Quote
Old 05-02-2019, 09:59 AM   #3
Engine: 466e
Rated Cap: its Yuge
Thanks Doe,
looks like those wires are also tied to that rail inside before they go on up to the cover. I have great access to remove them, is there even any reason to pull the valve cover completely off instead of just sliding it to the side like it is now. Anything i need to inspect while in there?
Old 05-02-2019, 10:49 AM   #4
Chassis: International 1753
Engine: 6.9 International
To the left in your picture, the plug in on the valve cover will have a ring of teeth holding it in the hole. Push all those teeth in with the right sized deep socket and the connector should push in. I do it that way because the connectors on the injectors can get brittle due to heat, and you don't want to break any off.
Booyah45828 is online now   Reply With Quote
Old 05-02-2019, 02:35 PM   #5
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Thanks Doe,
If it does not need removed I wouldn't
