The weather has turned cold and wet so work on the bus is not happening. Now I am looking into rebuild / replace the turbo, air compressor and radiator. I'm thinking I will replace the radiator. The existing radiator has a problem with the inlet interfering with the fan shroud. Someone actually cut thru the top of the fan shroud so it could collapse a little to be able to fit under the radiator inlet. This leaves only about 1/16 clearance between the fan and the top of the radiator shroud. I'm going to try to find the biggest, fattest radiator that will fit and give me proper clearance. I also want to add a tranny cooler. Looking for some input on that. If you have one, how is it set up? Is it in the engine compartment? Under the bus? How big is it?
Thanks in advance for any input
Bob
