Old 11-23-2018, 12:33 PM   #21
If you can find a radiator setup for a 2003 or 2004 IC CE300 it has a full rad and full I/C. Nice setup. I've got this on my CE300.
One of my friends just got a 2006 IC RE 300 and it looks like two radiators side by side on the very back. Curious what that setup is.
Daddy, can we go on a trip again??
'85 Thomas SafTLiner RE
3208 NA CAT MT643
boojiewoojie is offline   Reply With Quote
Old 11-23-2018, 01:33 PM   #22
EC I need to look into doing that to my 444e. I’ll soon have it turned up to 250 HO and I know the split rad won’t cool it..
technically your CE frame is still the same as an older 3800, just a matter of me finding the right radiator hose setup.. turbo pipes are easy.. everyone makes all kinds of pieces in 3 inch..
Christopher
Old 11-29-2018, 08:52 PM   #23
Meddle's Avatar
Coachwork: American Transportation Corp
Chassis: 40 foot
Engine: DT466HT 230 HP / 660 FP
Rated Cap: 72 Passenger
The weather has turned cold and wet so work on the bus is not happening. Now I am looking into rebuild / replace the turbo, air compressor and radiator. I'm thinking I will replace the radiator. The existing radiator has a problem with the inlet interfering with the fan shroud. Someone actually cut thru the top of the fan shroud so it could collapse a little to be able to fit under the radiator inlet. This leaves only about 1/16 clearance between the fan and the top of the radiator shroud. I'm going to try to find the biggest, fattest radiator that will fit and give me proper clearance. I also want to add a tranny cooler. Looking for some input on that. If you have one, how is it set up? Is it in the engine compartment? Under the bus? How big is it?
Thanks in advance for any input
Bob
Meddle is offline   Reply With Quote
Old 11-30-2018, 04:47 AM   #24
my 2004 CE300 has a nice full radiator and full intercooler.
Look up a rad for an 04 International CE300.
Old 11-30-2018, 05:33 AM   #25
The last 8 of the vin can tell you what part numbers those are
