02-15-2019, 04:40 PM
#101
Chassis: International FE300
Engine: Dt466e
Originally Posted by Bigfoot18
Did you get the t stat changed?
Putting new one in in just a minute
02-15-2019, 04:42 PM
#102
Engine: Dt466e
Originally Posted by o1marc
Why would it matter, he doesn't think coolant does anything.
I know that coolant does have a major part in the coolant system! I just dont believe it would matter in this particular scenario. I've spent hours trying to figure out the best coolant to use and have ended up deciding (I think!) To go with the dealer recommendations and use the extended life red coolant.......
02-15-2019, 04:43 PM
#103
Originally Posted by Entech.medic
Love it! I believe I have burped it well each time. This is also an issue that has been around since I purchased this bus. I'm in the process of swapping it right now so hopefully will know in an hour. Fingers crossed!
Lets hope so.
These engines really don't like being overheated and are very sensitive about the coolant quality.
Once you get it all figured out get the coolant mix perfected for maximum engine longevity.
02-15-2019, 04:46 PM
#104
I agree in this case it is irrelevant. But your statements show your ignorance on the basics of auto maintenance.
02-15-2019, 04:50 PM
#105
Engine: Dt466e
Lets hope so.
I will certainly do the best I can! Thanks
02-15-2019, 04:52 PM
#106
Engine: Dt466e
I'm not really sure which statements your speaking of but in the end it also doesnt matter. I have admitted to my ignorance along with the fact that I'm not a mechanic. Also let's face it, if I knew everything I wouldnt be on here letting you point out my ignorance!
02-15-2019, 04:56 PM
#107
Just don't bite the hand that feeds. Everyone here has useful and useless trivia to add. If the response doesn't suit you, just move along, it's the internet of which we have no control.
#108
It was a joke!
At 1500 rpm, any non foaming liquid would have cooled it if the system had good circulation.
02-15-2019, 05:08 PM
#109
Engine: Dt466e
Understood. I didnt answer his question but I did send him a thanks. Had no clue it would blow up so much. Appreciate it!
02-15-2019, 05:09 PM
#110
Engine: Dt466e
It was a joke!
I got it, but decided just to answer anyway! Thanks for all your help!
02-15-2019, 09:29 PM
#111
Coachwork: Amtran Genesis
Just read through this thread.... congratulations on getting it running! Just to play devils advocate, running a DT466 without the proper mix of coolant or proper mix of SCA’s will result in cavitation. This will occur even at 1500rpm. Very limited running in that condition may not hurt it too much. Just be aware that cavitation can and will destroy cylinder sleeves in short order if left unchecked.
02-16-2019, 03:47 PM
#112
Engine: Dt466e
Update:
Alright guys I got the thermostat changed last night but sense I have the front end torn apart and no headlights I couldn't road test it. I just got back driving about 15 miles (it would previously overheat half way through this "route") and did not get above 200 degrees! I cut apart the old thermostat and believe I see why it was stuck closed. I can not tell you guys how much I appreciate your input and a very special thanks to all of you who continued to help me without trying to make me feel like a tard! Even though in the end I may be one! Now I'm going to drain and fill with a 50/50 coolant ratio and hopefully will be running smooth. Thanks again everyone !
02-16-2019, 03:48 PM
#113
Engine: Dt466e
Here is a pic of the deformed gasket inside the thermostat
02-16-2019, 03:54 PM
#114
Don't know about the mangled gasket, but as long as it's out why not throw it in a pot of boiling water and see if it opens? Just for shits and grins. I think I remember testing my car's thermostat in that manner when I was in high school in the 80s.
02-16-2019, 03:56 PM
#115
Glad you got it running! Now be sure and put your preferred coolant/water mixture on your profile...
02-16-2019, 04:02 PM
#116
Engine: Dt466e
Yeah, I've done that before but these thermostats are different. That why I cut it open. There is a spring with a plunger kind of end but there is also a second spring inside the cone. I was confused because I couldn't blow through the thermostat once removed so cut it open to see the inside.
02-16-2019, 04:03 PM
#117
Engine: Dt466e
Will do! Thanks for your help bigfoot!
02-16-2019, 10:34 PM
#118
Congrats! Keep it healthy and happy!
02-16-2019, 10:35 PM
#119
Engine: Dt466e
Will do the best I can. Thanks again!
02-17-2019, 10:25 AM
#120
Your welcome! You can check your radiator flow out with a heat gun now and make sure its gonna cool good before you take it to the mountains.
