Old 03-18-2019, 05:43 PM   #1
DT466E Water Separator
So the list shows my DT466E uses a fuel/water separator. I have the old fuel filter off, but can't find the water separator anywhere on this motor, anyone know where it is located?
Old 03-18-2019, 06:00 PM   #2
on my DT360, the water separator is on the passenger side frame rail right where the fuel line comes into the engine compartment from the tank.. but i have a conventional
Old 03-18-2019, 06:02 PM   #3
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
Mine is conventional as well and it sits horizontally on the passenger side, near the front of the engine.
Dave
Old 03-18-2019, 06:14 PM   #4
For those of you that use a 3403 fuel filter, I started checking prices and see them generally in $15-$20 range. I went on eBay and saw a NAPA filter for $8.90. I called the local NAPA store after getting a quote of $19.99 at O'Reilly's and was told that filter is on sale right now for $8.90. I went ahead and ordered 3 of them at that price.
I'll go back and look for my separator on the FE.
Old 03-18-2019, 06:32 PM   #5
There is, on the passenger side of the motor, a 12"tall vertical oil filter under the turbo, and a horizontal filter under the alternator. I don't see anything that looks like a separator.
Old 03-18-2019, 09:14 PM   #6
Chassis: International FE
Rated Cap: 84 passengers
The separator will be on the frame rails. Just follow your fuel lines back to the tank. The horizontal filter on your engine is the coolant filter.
rensch26 is offline   Reply With Quote
