Old 06-24-2010, 09:19 PM   #21
Will's Avatar
Engine: DTA 360, Fuller 6-speed
Rated Cap: 53
Re: DTA 360 info
Something wasn't right with your DT360--one sample isn't enough data points for a conclusion. Mine averages 12+ and has gotten as good as 13.1 on a trip out to Iowa. I think they are nearly identical in everything except weight. The 5.9 Cummins weighs 950# and the DT360 weighs 1,300#. I'm assuming this is because International made naturally aspirated versions of everything and when you are running a farm tractor or industrial engine wide open all the time, the displacement is what determines the horsepower. They probably used one basic block design with minor changes to suit a number of displacements. The internals between the Cummins and International aren't that different. The extra weight seems to be in the block.
My bus conversion
Will is offline   Reply With Quote
Old 06-24-2010, 09:23 PM   #22
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Re: DTA 360 info
The extra weight is in the block, and the whole rotating assembly. The DT's rods and crank are a bit bigger than the Cummins.
nevrenufhp is offline   Reply With Quote
Old 06-29-2019, 09:15 PM   #23
Engine: 1991 International 6 Cylinders 5.9L Turbo
Thanks!
Really appreciate this old post. Nice to have info on our engine in one place. =) Thanks!
stormey79 is offline   Reply With Quote
Help & Info Please !! TheHobbits Conversion General Discussions 15 02-21-2013 08:05 PM
Hello all need some info on a possible bus purchase Darkrider Conversion General Discussions 4 01-24-2013 01:13 AM
Trying to Find Info about My New Bus BMM70047 Conversion Tutorials and How-to's 1 09-27-2010 10:54 AM
bus info newtoskool Conversion General Discussions 1 07-29-2010 02:53 PM
Vent Info bcschro Skoolie Conversion Projects 4 12-31-1969 07:00 PM
