Old 12-11-2009, 03:14 PM   #1
Re: DTA360 With Spicer 5 Speed Transmission Clunk
!st off, it's not a sports car and not designed for speed shifting take your time shifting and it will be a lot happier.
the clunk is a sign of something having excess clearance or being loose, crawl underneath the bus and make sure that all the bolts on the driveline are tight, bellhousing to engine, trans to bellhousing, u-joint to trans flange also the nut that holds the flange onto the trans, carrier bearing to frame and the rubber bearing mounts, check the rear end for excessive clearance or gear lash. then start looking at the rear suspension, are the axle to spring u-bolts tight, what condition are the spring mount bushings in etc. if you don't find an external reason for the clunk then possably their is something internal in the transmission that is not clearanced properly.like the end play on one of the shafts, or a failed snapring retainer.
Manual transmission with a 2 speed rearend crazycal Everything Else | General Skoolie Discussions 13 07-22-2015 02:28 PM
Spicer 5 speed GVW and towing QUESTIONS Hank's P-O-S International | Navistar Drivetrain 2 10-21-2014 11:50 AM
Replace 5 speed spicer with 7 speed spicer (double O/D) frank-id International | Navistar Drivetrain 2 02-13-2011 08:17 PM
1966 Crown 35' 41 passenger 220T Spicer 5 speed $4000 OBO slippers Classifieds | Buy, Sell, Swap 7 12-17-2009 09:57 PM
Transmission, NEED MORE SPEED BrutalBus83 Ford Drivetrain 7 09-14-2009 05:53 PM
