Old 06-15-2012, 08:51 PM   #11
Chassis: Genesis
Engine: Dt40
Re: Fuel MPG with DT466 and AT545???
Originally Posted by GreyEagle
A lot of that 10 will depend on da foot!!!!!!!!!
Well, with ours if you're on the Interstate, da foot is on da floor. ;)
And 2800 at 65mph is about 400 rpm lower that I am seeing.
bhays is offline   Reply With Quote
Old 06-20-2012, 12:52 PM   #12
Diesel Dan's Avatar
Engine: DT466/AT545
Originally Posted by crazycal
Originally Posted by Diesel Dan
I'm getting closer to 8mpg on mine doing 60-65 mph on flat highway with maybe some rolling hills here and there. I don't remember the ratio on my gear box but I am doing about 2800 rpm at 65mph.
If you were driving 55, what would your rpms be and do you think you mileage would be much better?
At 55mph I think my RPMs are closer to 2200-2500 and of course mpg would be better, but I don't know how much better since I've never calculated it at that speed. I would guess I could get 10mpg if I kept it down to 55. I think 10mpg is as good as it gets though.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-20-2012, 05:09 PM   #13
crazycal's Avatar
Wow. 3200 rpm seems pretty high. I thought they were governed at 2600-2800. What rear end do you have? I hope my rpms aren't that high. If it is, something will have to be done about that.
I'm hungry!
You Gotta Let Me Fly
Old 06-20-2012, 05:11 PM   #14
crazycal's Avatar
[quote=Diesel Dan]
At 55mph I think my RPMs are closer to 2200-2500 and of course mpg would be better, but I don't know how much better since I've never calculated it at that speed. I would guess I could get 10mpg if I kept it down to 55. I think 10mpg is as good as it gets though.[/quote:d6iky3yn]
What is your rear end ratio? If I could keep the revs around 2200-2400, I think I would be happy. I will know in a couple of weeks I guess.
I'm hungry!
Old 07-12-2012, 12:23 PM   #15
crazycal's Avatar
Mpgs turned out much better than hoped. I know I got a solid 10 going across country. I haven't done all the calls yet but will soon. The 545 definitely has to go for two reasons. I think it's on it's last leg and because of the nonlockup converter. A local guy told me about $2500 plus my 545 for a 643. This is not installed. That is a complete reman to Allison specs.
I'm hungry!
Old 07-13-2012, 05:33 AM   #16
i think you can get reman 643 or even 545 for 1800 in calif. shipping extra..
Old 07-13-2012, 02:38 PM   #17
crazycal's Avatar
Do you know where specifically for the 643?
I'm hungry!
Old 07-14-2012, 12:02 AM   #18
bus-bro's Avatar
Engine: 3208 na boat anchor
IIRC, the at545 mates to a SAE 3 bell housing. The mt643 mates to a SAE 2 bell housing. An SAE 2 bell housing for a dt466 should be easy to find.
Old 07-14-2012, 12:43 AM   #19
crazycal's Avatar
It already has a #2 on there. Then there is another smaller adapter that brings it to a 3. If I take that adapter off, I have a 2. Just not sure of what else I need to complete the changeover. I know I can use the same shifter.
I'm hungry!
Old 07-14-2012, 08:50 AM   #20
not much...
1995 DT466 Fuel line gildorr Mechanical and Drivetrains 5 06-30-2014 10:09 AM
AT545 overfull! bus-bro Mechanical and Drivetrains 2 07-27-2010 11:03 AM
at545 transmission The Wanderer Classifieds | Buy, Sell, Swap 15 05-24-2007 12:13 AM
Does a MT643 fit instead of a AT545 ????? Protecx Conversion General Discussions 1 02-09-2007 09:14 PM
I need a Used or Rebuilt Transmission (AT545) ParadigmCrime Everything Else | General Skoolie Discussions 6 09-10-2006 10:04 AM
